jeansain Posted February 7, 2005 Share Posted February 7, 2005 Hi Everyone! Here in Canada, DRL are compulsory and since the early 90's all cars come with them. Mine comes from the US so it didn't have DRL originally. To make it Canadian legal, the importer rewired it so that when I turn off the engine the lights go off, even if the switch is on. So leaving the switch always on did the trick. Now all of a sudden today, the parking lights stay on all the time, even with the engine and the light switch off , unless I disconnect the battery. Anyone knows what went wrong? TIA Quote Link to comment Share on other sites More sharing options...
sea#3 Posted February 7, 2005 Share Posted February 7, 2005 By an chance were you cleaning your car?????? You have accidently switched the parking lights on , the switch is on the centre steering wheel console between the turn signal switch and the wiper switch Just flip it the other way SEA#3 Quote Link to comment Share on other sites More sharing options...
jeansain Posted February 7, 2005 Author Share Posted February 7, 2005 By an chance were you cleaning your car?????? You have accidently switched the parking lights on , the switch is on the centre steering wheel console between the turn signal switch and the wiper switch Just flip it the other way SEA#3 I feel sooo stuuupid! That was it!! But I should say that this is a terrible design. I can easily see someone not even noticing that their lights are on and draining their battery. Or worse, thinking there is a short in the car and having a dishonest mechanic take advantage... What's the purpose of having an additional switch for the parking lights anyhow? Anyway, many thanks. Quote Link to comment Share on other sites More sharing options...
Seahag1978 Posted February 7, 2005 Share Posted February 7, 2005 It's a silly design. I knew about the switch, but must have hit it by accident. The parking lights were on all day while at work... luckily the battery didn't run down. Now, as habit, I glance back to be sure they're off. Quote Link to comment Share on other sites More sharing options...
felipe01forester Posted February 7, 2005 Share Posted February 7, 2005 Having an extra switch for the parking lights is kinda dumb. But, it sorta makes sense for me because in my Forester, everything electrical gets cut off when I turn off the key, so if you're stranded and you can't start the car, you just flip those on whenever you can't turn the main light switch on. Quote Link to comment Share on other sites More sharing options...
Tiny Clark Posted February 7, 2005 Share Posted February 7, 2005 I'll go on record once again to say hell-of-a-good idea, but a damn bad place to put the switch. Quote Link to comment Share on other sites More sharing options...
mwatt Posted February 10, 2005 Share Posted February 10, 2005 I feel sooo stuuupid! That was it!! But I should say that this is a terrible design. I can easily see someone not even noticing that their lights are on and draining their battery. Or worse, thinking there is a short in the car and having a dishonest mechanic take advantage... What's the purpose of having an additional switch for the parking lights anyhow? Anyway, many thanks. a short summary of Federal Motor Vehicle Safety Standard 108 (in effect since 1969): "a vehicle exterior lighting system must be operable to make vehicle conspicious on the road.......at all times" (ignition on OR off). Since Subaru has chosen to wire headlamp/marker lamp circuit thru igniton side of electrical system (supposedly to PREVENT leaving lights on after vehicle is shut down), the switch on top of the steering column is required---to make marker lamps operable with ignition off. Quote Link to comment Share on other sites More sharing options...
