MIKEKACH Posted February 7, 2005 Share Posted February 7, 2005 How much should a Legacy bounce if the struts are good or bad ? Are they the same as a shock equiped type ? Have the 94 Legacy SW with 145000 miles ,non-air assist strut. does the good olde 220 lb(ok 99.78 Kg if you only read metric) guy jumping on/off the bumper test apply ? Or do they need to be replaced no matter what? The car was never abused or driven offroad (until I got it a month ago ).... Many Thanks Quote Link to comment Share on other sites More sharing options...
Beaudiggity Posted February 7, 2005 Share Posted February 7, 2005 The jumping on the bumper works if your trying to diagnose a simple strut. When you bounce on the bumper and let go it should only bounce momentarily then stop. If not your struts are bad. A good way to tell also is in cornering. How bad does it lean to one side in a tight corner? What about when you hit those little waves in the road that seem to be everywhere. Shouldn't feel like a boat or they are bad. just my .02 on struts. I've replaced a few. How much should a Legacy bounce if the struts are good or bad ?Are they the same as a shock equiped type ? Have the 94 Legacy SW with 145000 miles ,non-air assist strut. does the good olde 220 lb(ok 99.78 Kg if you only read metric) guy jumping on/off the bumper test apply ? Or do they need to be replaced no matter what? The car was never abused or driven offroad (until I got it a month ago ).... Many Thanks Quote Link to comment Share on other sites More sharing options...
