5 speed MT clutch not slipping?
5 replies to this topic
#1 tracedog67
tracedog67
    USMB Regular
  • PipPipPip
  • 69 posts
  • Cincy, OH
Posted 09 February 2005 - 12:36 PM
Fellers,
About a month ago I posted my clutch was slipping and the RPMs flaring on just normal acceleration. Since the weather is just a litttle warmer the clutch hasn't been slipping hardly at all lately. I added Lucas transmission additive shortly after it started but I don't know if I can fully attribute the less slippage to Lucas or not. I was calling the dealer to price a new clutch install but maybe now I can put it off until i hit 250k miles. Any thoughts
thanks
Tdog
'97 OBW 239,855 miles 5MT
#2 subeman90
subeman90
    Soobologist
  • Moderator
  • 2,805 posts
  • Akron PA
Posted 09 February 2005 - 12:50 PM
Lucas has nothing to do with your clutch slipping or not. The clutch is a dry plate (or darn well better be) and the oil hopefully will never touch it (if it does you have other issues). As for slipping and not slipping....lucky you...keep driving and when it gets worse then replace it. save your money and run it till it really slips.
Matt
#3 powderhound
powderhound
    Eat, Live, Breath Subaru
  • 359 posts
  • MSP
Posted 09 February 2005 - 12:51 PM
I too was experiencing slippage in fourth gear when the weather was much colder...about -20F. Now it is warmer and has subsided. Setright said it was the extreme cold effecting the friction coefficient of the clutch lining. A sign, he said, of age but not imminent failure.
Why would a transmission additive affect the clutch?
Is that your original clutch?
#4 tracedog67
tracedog67
    USMB Regular
  • PipPipPip
  • 69 posts
  • Cincy, OH
Posted 09 February 2005 - 01:27 PM
You're right, Lucas wouldn't affect the clutch at all. I bought the car at 182k miles from a small dealer. The previous owner was the original owner and drove 72 miles one way to work each day and i think it is the original clutch. I had the head gaskets done at 191k miles which isn't too bad either.
tdog
#5 unverviking
unverviking
  • 289 posts
  • Spencerport, NY
Posted 09 February 2005 - 09:18 PM
My 93's clutch was slipping in 5th while cold. Now that it has warmed up here, it has subsided. I kinda thought that maybe I got some snow pack into the clutch (not sure if there's an access hole for checking the clutch itself) after driving thru several big drifts.
Hopefully I can "nurse" it till the spring. Want to trade up to a newer (95-96) OBW with a 2.2 or an Impreza/OBS.
#6 Setright
Setright
    Elite Master of the Subaru
  • 3,176 posts
  • Denmark
Posted 10 February 2005 - 01:22 PM
Well, nearing 250k miles, I would suggest the old adage:
If it ain't broken, don't fix it!
Opening an engine/gearbox, especially one that has racked up the miles, always involves a little risk. What might break during disassembly? What other things will you find wrong with it?
