Welcome to Ultimate Subaru Message Board, an unparalleled Subaru community full of the greatest Subaru gurus and modders on the planet! We offer technical information and discussion about all things Subaru, the best and most popular all wheel drive vehicles ever created. We offer all this information for free to everyone, even lurkers like you! All we ask in return is that you sign up and give back some of what you get out - without our awesome registered users none of this would be possible! Plus, you get way more great stuff as a member! Lurk to lose, participate to WIN*!
* The joy of participation and being generally awesome constitutes winning ** Not an actual guarantee, but seriously, you probably won't regret it! Serving the Subaru Community since May 18th, 1998! |
ej22 with no ecu conversion
#1
Posted 10 February 2005 - 02:57 AM
I got to thinking, would it be possible to make a EJ22 run without an ECU if you wired the fuel injectors in with a resistor to the spark plug wires. With Constant power to the coil/coil pack, so it would have spark on its own and would still work via a distributor somehow rigged up. The wires would run a cylinder ahead of the spark. Like It would start like this
Plug wire #1 - resistor to fuel injector 3
Plug Wire #3 - resistor to fuel injector 2
Plug Wire #2 - resistor to fuel injector 4
Plug Wire #4 - resistor to fuel injector 1
So when the 1 cylinder sparked, it would blow fuel to 3 cylinder (the next in the firing order) 3 would spark sending fuel to 2 cylinder..
Prolly not possible, but I thought I'd throw the idea out there
#2
Posted 10 February 2005 - 04:46 AM
im in the middle of finding out how to run a ej ignition system without an ecu so i can run a propane carburetor
#3
Posted 10 February 2005 - 07:41 AM
#4
Posted 11 February 2005 - 03:46 AM
You'll need an ECU to run the ignition since it is based upon the signals sent from two sensors, the crank angle sensor and the cam angle sensor, The only way around that would be for find one of those EJs with a distributor. I have only heard that they exsist, I personally have never seen one. You probably could carburate an EJ engine, but I'm not sure why you would want to do that.
hmmm might have a problem... there i wonder if the ECU could be modified so it would run without any fuel control inputs
the reason i want to run a carb is that LPG/Propane here is about 1/2 the cost of petrol.....and im not willing to spent 2900 euros to import a LPG fuel injection system from europe (Italy actualy)
#5
Posted 11 February 2005 - 03:48 AM
#6
Posted 11 February 2005 - 03:55 AM
If you really don't want any computer stuff, you could just put a carburetor on it. However, I don't see too much of a reason to ditch the factory fuel system.
some one has done a hack&slash on the loom and all the wires going to the ecu......and my wiring skill blows chunks
#7
Posted 11 February 2005 - 04:30 AM
#8
Posted 11 February 2005 - 04:49 AM
damn hijackers
sorry bro
#9
Posted 11 February 2005 - 06:22 AM
Some ej18s over here have distributors (From a very early Legacy DL I think).
#10
Posted 11 February 2005 - 06:45 AM
do they now......
#11
Posted 11 February 2005 - 07:37 AM
#12
Posted 11 February 2005 - 09:47 PM
~Josh~
#13
Posted 11 February 2005 - 09:57 PM
LPG dedicated carb and i have one
btw a 'US' gallon of gasoline here costs $3 'US' equivilant LPG costs about $1 US per gallon
#14
Posted 11 February 2005 - 10:44 PM
do they now......
i must do some serious looking
Don't get your hopes up, they work basically the same as a EA82 SPFI distributor, so you'll still need a computer.
#15
Posted 11 February 2005 - 11:10 PM
