tracedog67 Posted February 11, 2005 Share Posted February 11, 2005 Fellers, I am getting codes on my '97 OBW (240k) for the EGR and knock sensor. Where can I find the knock sensor? Autozone's website says mounted on rear of cylinder block under the valve covers. thanks Tdog Quote Link to comment Share on other sites More sharing options...
Legacy777 Posted February 11, 2005 Share Posted February 11, 2005 If you look straight down, just to the right (driver's side) of the throttle body, you'll see it. It's the black round thing with the bolt in the middle, and the wire coming out with the white connector http://www.main.experiencetherave.com:8080/subaru/images/injectors/DCP_2481.JPG Quote Link to comment Share on other sites More sharing options...
mattocs Posted February 12, 2005 Share Posted February 12, 2005 I just did mine last weekend. It took about 5 minutes. Make sure you have a 10 inch socket extention to get to it. Mine was real tight, so a little WD-40 might help. Quote Link to comment Share on other sites More sharing options...
joeo Posted February 12, 2005 Share Posted February 12, 2005 I recently did this on our 1995 wagon. Tooks some notes and pictures of the process. Hope it helps: http://www.lovehorsepower.com/SubaruDocs/subaru_legacy_knock_sensor.htm Quote Link to comment Share on other sites More sharing options...
ron2368 Posted February 12, 2005 Share Posted February 12, 2005 Can the sensor be cleaned / reconditioned? Would you only replace it if there was a code ? Thanks Quote Link to comment Share on other sites More sharing options...
