Possible solution to the weak axle problem
9 replies to this topic
#1 Hondasucks
Hondasucks
    Subaru Technician
  • 4,760 posts
  • Vancouver, WA
Posted 25 August 2003 - 10:43 PM
Check this out
http://www.diversifiedcryogenics.com/ Cryogenic treating looks relatively inexpensive, and seems to make things last a lot longer. Mostly what gets broke on the axles is teh joints right? Send those in and have them Cryo treated and see if it helps.
#2 XSNRG
XSNRG
    Elite Master of the Subaru
  • 3,657 posts
  • Olympia
Posted 26 August 2003 - 12:04 AM
I wonder if they could get my whole car in there.:brow:
#3 oddcomp
oddcomp
    Subaru Master
  • 1,763 posts
  • longview ,wa
Posted 26 August 2003 - 09:06 AM
my old highschool metal shop /cad /cam /cnc shop teacehr does cryotreating or did last i knew
does cranks engine blocks anything pretty much that will fit in his cryo freezer
works well on gun barrels also
#4 XSNRG
XSNRG
  • 3,657 posts
  • Olympia
Posted 26 August 2003 - 09:56 AM
Yep, a lot of guy's are doing gun barrels/actions around here and the Toyota/Samuri gang are all doing thier Burfield's (spl?) I guess the guy that started doing the Burfields is in Graham WA, he's well known for it.
It would be nice if we could put a front stub in the rear, the fronts are solid as opposed to the hollow rear ones. I wonder if the 510 stubs are solid? Anybody know? I believe they are oart of the axle.
#5 Hondasucks
Hondasucks
    Subaru Technician
  • 4,760 posts
  • Vancouver, WA
Posted 31 August 2003 - 04:21 PM
510 stubs are part of the axle kinda, they are the same as an EA71 U-Joint axle, there is one bolt in the center of the U joint that holds the axle into the diff, and then right next to the U joint there is a flange that the axle bolts to, but it is a lot easier to take the one bolt out, than to unbolt all 4 bolts holding the axle to the flange. The 510 axle wouldn't work on a newer car though, due to the way it attaches to the outer axle stub. Like the older soob, it has a 4 bolt flange, rather than the splined stub and spring pin. Perhaps someone with access to a machine shop could make some like, Chromoly axle stubs or something?
#6 beauregaardhooligan
beauregaardhooligan
    Subaru Fanatic!
  • 424 posts
  • Greenville, SC
Posted 31 August 2003 - 05:01 PM
Keep in mind, if the stub is stronger, something else will be the weaker link.
What would be next?
Which is easier to fix?
#7 Qman
Qman
    Happiness is... no lag!!
  • Moderator
  • 11,119 posts
  • Sumner
Posted 31 August 2003 - 05:24 PM
That's right Ed. When I broke the stub on the Rubicon I was up and running again in 15 minutes. But that too depends on which end of the stub you break.
Qman
#8 bushbasher
bushbasher
    exhaust fume addict
  • 1,707 posts
  • Sooke B.C. Canada
Posted 31 August 2003 - 11:47 PM
With cryo-treating our axles may still be the weak point, but still be stronger. I don't see cryo-treating doing so much to our axles that they will become unbreakable. I also think that unless the axles become unbreakable they would be impractical, because everytime we break an axle we will have to send a new one to the freezer. Any body know what people charge for this kind of work?
#9 beauregaardhooligan
beauregaardhooligan
    Subaru Fanatic!
  • 424 posts
  • Greenville, SC
Posted 01 September 2003 - 08:27 AM
Nothing is un-breakable!
The point I'm trying to make is what would be next to break if the axle stubs won't, and how hard would it be to fix in the woods.
I understand a lot of 4x4ers use regular u-joints for just that reason, cheap and easy to fix.
#10 "EJ"
"EJ"
    1000+ Super USER!
  • 1,115 posts
  • Jerzey
Posted 01 September 2003 - 08:59 AM
Again Ed is on top of things again, like Ken said it all depends on what breaks. I would rather have the half-shaft break cost wise compared to the tranny.....
