92 legacy rear wheel bearings
7 replies to this topic
#1 ron2368
ron2368
    USMB Regular
  • 125 posts
  • Lancaster PA
Posted 12 February 2005 - 08:11 PM
I have a fwd . A while back I had a rear wheel noise and removed the rear bearing in the process of looking for the problem.
The nut I removed to get to the bearing was super tight I had to use a bar to loosen it. I thought these nuts should be tight and then backed off a slight bit. Could someone give me an idea on how tight it should be.
Also the bearing did not seem very greasy, should these bearings be cleaned and regreased occasionally or just leave it alone?
Thanks
#2 Setright
Setright
    Elite Master of the Subaru
  • 3,176 posts
  • Denmark
Posted 13 February 2005 - 03:14 AM
These bearings are weak and no amount of grease will save them :-(
Sorry, dont have the torque spec.
#3 ron2368
ron2368
    USMB Regular
  • 125 posts
  • Lancaster PA
Posted 13 February 2005 - 07:13 PM
Last time I took off the nut, the outer part of the bearing popped out easily. This time I could not get it out. I even took off the caliper and rotor, but nothing. It seemed dry but did not look like there was anything I could do so I put it all back together. Guess I need to get a manual!
#4 frag
frag
    Soob shade tree mechanic
  • 1,777 posts
  • Montréal, Québec, Can.
Posted 13 February 2005 - 08:21 PM
Thanks
Haynes gives 123-151 ft-lbs of torque for the rear wheels hub and bearing retainer nut for a FWD car.
#5 ron2368
ron2368
    USMB Regular
  • 125 posts
  • Lancaster PA
Posted 13 February 2005 - 08:51 PM
Thats alot, right? almost like a head bolt. Though the little crimp lined up at the same place, I don't think I got anywhere close to those numbers. Should I give another try and really lean on it?
Thank you!
#6 SevenSisters
SevenSisters
    Subaru Nut
  • 512 posts
  • Cleve/Akron Ohio
Posted 13 February 2005 - 10:49 PM
The little crimp can't line up at the same place if you use a new nut like you're supposed to.
Pound out the old bearing. Buy new bearings, seals, nut, and a torque wrench. You'll be good to go if you lube it properly.
#7 ron2368
ron2368
    USMB Regular
  • 125 posts
  • Lancaster PA
Posted 14 February 2005 - 07:53 PM
You may think I am a total lunatic, but there was nothing wrong with the bearing in the first place( at least before I worked on it). While exploring for another problem , I just thought the bearing looked dry.
Well I should have watched TV instead of doing something useful. Guess at the least I need to retighten it.
#8 SevenSisters
SevenSisters
    Subaru Nut
  • 512 posts
  • Cleve/Akron Ohio
Posted 14 February 2005 - 08:26 PM
I wasn't trying to discourage you, just saying you need to have the right tools and procedures before tearing into something as important as wheel bearings.
Only way to learn is to have at it. Good luck with what ever you try next.
