subie94 Posted February 13, 2005 Share Posted February 13, 2005 has anyone here had their spring on the clutch pedal brake on them? i found out the other day that mine has,needed to find out how hard it was to replace. i think that's what is causing the squeal from the area where the cable and hill holder go to the trans,found if i use my toe an pull up on the pedal towards me squealing stops. any help on this matter would be appreciated thanks,cuz the noise is very annoying. Quote Link to comment Share on other sites More sharing options...
Setright Posted February 14, 2005 Share Posted February 14, 2005 Okay, you're gonna have to bite the bullet and visit an authorised dealer. Sube make a "Clutch spring kit", which includes the spring and new bushings, washers, and lock rings. Fitting is not easy, since you need to push the pedal down to squeeze the spring into the bushings. Tricky when you are already upside down below the dashboard! Word of advice: Cover the firewall and footwell with a big cloth or newspaper to avoid dropping things behind the carpet. The lock rings are IMPOSSIBLE to find downthere. My old car has two full sets still kicking about under the carpet... Quote Link to comment Share on other sites More sharing options...
subie94 Posted February 14, 2005 Author Share Posted February 14, 2005 Okay, you're gonna have to bite the bullet and visit an authorised dealer. Sube make a "Clutch spring kit", which includes the spring and new bushings, washers, and lock rings. Fitting is not easy, since you need to push the pedal down to squeeze the spring into the bushings. Tricky when you are already upside down below the dashboard! Word of advice: Cover the firewall and footwell with a big cloth or newspaper to avoid dropping things behind the carpet. The lock rings are IMPOSSIBLE to find downthere. My old car has two full sets still kicking about under the carpet... thanks for the info,will let you know how much fun i had. Quote Link to comment Share on other sites More sharing options...
subie94 Posted February 15, 2005 Author Share Posted February 15, 2005 callen the dealership,they said they sell everything separate.spring it self only $3.00 gonna pick it up tomorrow an gonna see about putting it in then. Quote Link to comment Share on other sites More sharing options...
Setright Posted February 15, 2005 Share Posted February 15, 2005 The plastic bushings are likely to be worn out, I suggest you replace them! Quote Link to comment Share on other sites More sharing options...
subie94 Posted February 16, 2005 Author Share Posted February 16, 2005 all fixed,as it turns out the dealership had wrong spring,correct one would had been 15 bucks(special order). found one in salvage yard.it's in an working that's all i care about. Quote Link to comment Share on other sites More sharing options...
