subieman Posted February 14, 2005 Share Posted February 14, 2005 I have a 90 legacy auto tranny which is bad. I found a tranny for a 98 legacy. What would I need to mod to make this tranny work in the 90? I know I'll have to replace the rear diff cuz the 90 has a 4.11 gear ratio. Maybe the computer also? Please help and let me know if this is even possible. Thanks, Quote Link to comment Share on other sites More sharing options...
ballitch Posted February 15, 2005 Share Posted February 15, 2005 if your going from 2wd to AWD tranny you'll need the tcu and all wires, and maybe the ecu also, i have no evidence to back that up tho, they will both bolt up however, as you said different rear diffs and maybe have to swap out the whole driveline, and maybe, just maybe, you might have to lengthen or shorten it, dont know about wheelbases for those cars being the same and all. thats all i can tell ya man. ~Josh~ Quote Link to comment Share on other sites More sharing options...
Legacy777 Posted February 15, 2005 Share Posted February 15, 2005 Simple answer is.....you can't. In 96 subaru introduced the phase 2 4eat tranny. It added a few more features, sensors, and other gadgetry. The connector plugs changed as well. So despite the fact it will physically bolt up, you'll run into issues with the connectors. I suppose if you were really ambitious you could rewire the connector and match as many of pin outs as you can with the old setup. It would "probably" work ok.....however this a completely wild rump roast guess. Quote Link to comment Share on other sites More sharing options...
subieman Posted February 16, 2005 Author Share Posted February 16, 2005 Bummer, thanks for the info. Quote Link to comment Share on other sites More sharing options...
ballitch Posted February 16, 2005 Share Posted February 16, 2005 but can you swap the awd drivetrain out of a 98 legacy sedan and through it into a 95 legacy sedan, the 95 has no awd drivetrain. ill have to swap the tcu, maybe the ecu, and all the wires that go from tcu--->ecu right, and of course the rear end driveline, and all that stuff.......or would it be easier to through the drivetrain out of a 90 legacy wagon with 5MT Fulltime 4wd into the 95 legacy with no awd. out ona limb i know. ~Josh~ Quote Link to comment Share on other sites More sharing options...
mudrat79 Posted February 16, 2005 Share Posted February 16, 2005 Hey I dropped you a pm as well.... This swap CAN BE DONE .......I'VE DONE IT....... :cool: The Only difference I came across is the fact that the 96 and Newer trans Will have an electronic speed sensor at the trans for speedometer.....on the older trans it is 100% mechanical.... To do this swap Pull the speed sensor and Just stuff your factory mechanical speedo in the same location..... You may also need to use your stock trans mounts .....I think there was a slight change there as well, but the 2 or 3 different generations of Trannys will interchange...... I went to my Local Dealer and verified there is NO CHANGE in the PIN LOCATIONS between trannies..... I did a 97 Legacy Wagon trans into a 91 Sedan...... Hope this clears things for folks..... John.... Quote Link to comment Share on other sites More sharing options...
Legacy777 Posted February 16, 2005 Share Posted February 16, 2005 That's interesting to hear John. All the info I have see shows that the phase 2 transmissions have a different style plug connector. Quote Link to comment Share on other sites More sharing options...
idosubaru Posted February 16, 2005 Share Posted February 16, 2005 if the pins match, even if it's a different connector all he would have to do is splice in the connector from his old (trashed anyway) trans. 2 FSM's would be really nice, that would make this job much easier. tell you exactly what is what. Quote Link to comment Share on other sites More sharing options...
subieman Posted February 17, 2005 Author Share Posted February 17, 2005 Thanks for the wonderful info mudrat. You have gone well beyond the norm! I will be sure to contact you if I run into trouble with my swap. Thanks again, Quote Link to comment Share on other sites More sharing options...
subieman Posted April 15, 2005 Author Share Posted April 15, 2005 I just wanted to update everyone on my progress with the 1998 Legacy tranny install. In two words.... IT WORKS!!!! it is possible to use a 2nd gen Legacy tranny in a 1st gen Legacy!!! WOOHOO! Quote Link to comment Share on other sites More sharing options...
Will Smith Posted April 15, 2005 Share Posted April 15, 2005 congratulations Jeremy. A home run if I ever saw one! Quote Link to comment Share on other sites More sharing options...
simbey1982 Posted April 17, 2005 Share Posted April 17, 2005 way to go out on a limb....congrats Quote Link to comment Share on other sites More sharing options...
Mike W Posted April 18, 2005 Share Posted April 18, 2005 Thanks to Subieman and John for this info. I too might be going down this road, so thanks for the low-down. Oh yeah, how was driveline fit? Same length? Tranny crossmember fit ok? Thanks! Quote Link to comment Share on other sites More sharing options...
