Thermo fan switch question
6 replies to this topic
#1 subestyle18
subestyle18
    USMB is life!
  • 210 posts
  • Woodinville
Posted 14 February 2005 - 09:03 PM
This is on my 83 gl wagon 4wd. Over the last month i have noticed that the temp gadge in the car will go up to a certin point and stop. Slowly that point where it stops has been going down. Last week not knowing if the two systems were connected i drove the car hard for a while and thought the gadge showed barely over the bottom line I knew i should be at least around the middle line. Then checked while car was still running and the radiator fan was not on. I tested the fan and it runs fine with 12v of power. The radiator, fan, and water pump are all only three months old, so i feel that no damage has accured by overheating. I replaced the fan switch in the radiator but that didnt change any thing. Currently i wired the fan to run with the key in the on position. I was wondering where the gadge's sending unit is or any other ideas on why these are not working right.
On another maybe connected not by battery gadge will read less then ten volts when i start and raise to around 12 when running, but my battery reads 12.6 with the car off and 13.3 when runing when i test with a multimeter.
Any ideas on ether of the situations would be great.
Thanks
David
#2 Skip
Skip
    Flatuous Blather
  • Moderator
  • 8,991 posts
  • Latrobe, Pennsylvania
Posted 15 February 2005 - 08:36 AM
check for the small braided wire
that grounds the radiator.
sounds like the dash gauge for the voltage may be
out of calibration.
Wire your multimeter to a cig lighter plug
and compare.
#3 NV Zeno
NV Zeno
    Elite Master of the Subaru
  • 3,026 posts
  • Ponderosa Ranch, Nevada
Posted 15 February 2005 - 10:32 AM
It's possible your gage may be correct, your engine is not heating up all the way. Could be the thermostat is faulty (happened to me)..use only genuine Subaru thermostat.
#4 subestyle18
subestyle18
    USMB is life!
  • 210 posts
  • Woodinville
Posted 15 February 2005 - 01:10 PM
I'll check the ground on the radiator, just by feeling the hoses and such in the radiator it seems to be heating up fine. The more i dig the more i find weird stuff in the wiring. I only get around 4.5v out of the cig outlet.
thanks for the idea i'll give it a shot.
David
#5 noob2soob22
noob2soob22
    USMB Regular
  • PipPipPip
  • 100 posts
  • Marshall, MI
Posted 01 December 2011 - 06:48 PM
1983 gl wagon 4wd
im having similar problems, my fan wont kick on when its suppose to. but someone ran a hot wire from the battery to the fan and run it off a toggle switch. i cant figure out why my fan wont kick on. Now, i have two therm switch's on my radiator only one is hooked up though. kinda weird. im just goin to install a toggle switch into the dash. i rather control my fan anyway. its the unplugged wires up by the relay center that's bugging me??
Edited by noob2soob22, 01 December 2011 - 06:51 PM.
#6 MilesFox
MilesFox
    Catch this Fox!
  • 9,130 posts
  • Madison/Milwaukee, WI
Posted 01 December 2011 - 07:20 PM
check your other thread, look for the wire on the top of the radiator. Yu should remove the toggles and extra wires, and make your troubleshoots first before any electrical modifications.
you can make a toggle to act as the ground for hte thermoswitch. You woud run it in parallel, and manually override it to come on when you want, but you can never leave it off becausse the thermoswitch (should) make the fan come on anyway.
#7 noob2soob22
noob2soob22
    USMB Regular
  • PipPipPip
  • 100 posts
  • Marshall, MI
Posted 01 December 2011 - 10:56 PM
ok the wire on the top of the radiator is gone i can see where ther was a ground fastened to frame near the radiator. i will upload pics.
now when tracing i should only have to trace from the fan to the thermo switch, corect?
not that complicated, its all within the 2-3 foot stretch?
