How best to clean IAC?
3 replies to this topic
#1 Phaedras
Phaedras
    Eat, Live, Breath Subaru
  • 305 posts
  • Somerville
Posted 15 February 2005 - 06:07 PM
Heard about the Idle Air Control Valve (that round bar at the front of the throttle body) being a common problem, causing weird idle. After taking one at a local junkyard apart (my car is a daily driver) I see that it has a motor on the left side, and a hollow tube with a rod and spring at the other. I'm wondering how I can get in there to clean everything out. Is there a way to dissemble it or should I just spray in some carb cleaner and hope for the best?
#2 hooziewhatsit
hooziewhatsit
    I fix old cars
  • 1,333 posts
  • Klamath Falls
Posted 15 February 2005 - 08:41 PM
When I cleaned the one on my wifes loyale, I used vice grips to break loose the screws. Then I took the whole thing out and hit it pretty good with carb cleaner.
I'd imagine you could just hit with carb cleaner while it's still in though.
#3 Phaedras
Phaedras
  • 305 posts
  • Somerville
Posted 15 February 2005 - 10:56 PM
But don't you need to wipe off the surface after you've sprayed it with any kind of solvent? Does breaking it down by itself already help?
#4 Phaedras
Phaedras
  • 305 posts
  • Somerville
Posted 16 February 2005 - 01:41 PM
bump
