1984 2 wheel drive to 4wd
7 replies to this topic
#1 skybren
skybren
    USMB Regular
  • PipPipPip
  • 43 posts
  • portland
Posted 16 February 2005 - 11:55 AM
I have a 1984 2 wheel drive Subaru wagon in very good shape. Will the running gear off a 1983-1984 4wd subaru wagon bolt up to my 2 wheel drive to make it 4wd.
If so are there any articles out there to show me how..... thanks in advance
#2 84gl
84gl
    Eat, Live, Breath Subaru
  • 294 posts
  • Southwest VA
Posted 16 February 2005 - 12:01 PM
yes it will you may have to tap some holes inthe rear but thats all i know of
and there is a write up on this link www.ultimatesubaru.org/forum/article.php?a=16
#3 mcbrat
mcbrat
    Brattitude Adjustment
  • Administrator
  • 11,183 posts
  • Central Iowa
all of the captive nuts may not be there, but that swap has been done lots of times.
you will want the 4WD suspensions, as well as the gas tank, unless you lift it at least 4" at the same time. (the 4WD tank has theindent to allow for the rear diff...
I'm sure others will chime in with more things.....
#4 the sucker king
the sucker king
    great fisherman
  • 1,988 posts
  • Lyons, Colorado
Posted 16 February 2005 - 01:09 PM
i did it with an 80 hatch and the ONLY holes i had to drill were to mount the 4wd shift lever. the diff hanger holes were there. of course it could differ from year to year. also some people complained about having to bang more space for the tranny. mine started out as an auto, and i had no issues.
#5 MorganM
MorganM
    Do you Subaru?
  • 8,390 posts
  • TwinCities
Posted 16 February 2005 - 01:22 PM
My '88 had the 4WD gas tank even though it was 2WD; check that before you go swaping in the rear end :)
#6 MilesFox
MilesFox
    Catch this Fox!
  • 10,686 posts
  • Madison/Milwaukee, WI
Posted 16 February 2005 - 03:32 PM
i had an 83 wagon, fwd 5spd, i converted it to 4wd and the holes for the diff hanger bolts were already there
on ea82's the 23d and 4wd tanks are the same
but yeah, everything will swap over, so long as you have all the parts u need
#7 MorganM
MorganM
    Do you Subaru?
  • 8,390 posts
  • TwinCities
Posted 16 February 2005 - 04:06 PM
Holes in the unibody for the outer diff hanger brackets were not drilled on mine. I could tell exactly where they went; as the unibody had a hole drilled in the first layer of the body but it wasnt fully drilled out or tapped. Pretty easy to drill out though and I just self-tapped with some taiperd tip bolts :)
#8 MilesFox
MilesFox
    Catch this Fox!
  • 10,686 posts
Posted 17 February 2005 - 02:15 PM
on ea82 the holes wont be ther but they will be for ea81, for all that i have seen
in my ea81 i went from fwd 5spd and i had to beat out the tunnel for a 4wd 5spd from ea82, cut a hole in the side. the 4spd isnt as big so it wont take as much as mine and most kikely wont have to cut anything. the tranny tunnes will be different for whatever tranny came with, but the auto tunnel will be the biggest
