New exhaust, Now RX sounds like a Toyota pickup????
26 replies to this topic
#1 tizzle
tizzle
    Subaru Nut
  • 628 posts
  • Bellingham
Posted 16 February 2005 - 06:37 PM
I got the techworks header/downpipe, with custom 2.5 piping into a flowmaster muffler. NO cats. And I can't stand the way it sounds!!!:banghead: It's obnoxious. Sounds great at idle but, then you get going and get this gurgly tin can/ fart can sound that overpowers the good sound, and it sounds like a toyota pickup. Is this just because of the flowmaster? should I try having a resonator put in or a cat, or what? I guess I would rather have no noise, than have it sound like this.
#2 carfreak85
carfreak85
    Temple of Fuji
  • 5,213 posts
  • Cascadia
Posted 16 February 2005 - 06:44 PM
Yeah, try a resinator, different muffler or even a cat. Find what works for you.
#3 archemitis
archemitis
    guy smiley
  • 3,554 posts
  • the big minnie
Posted 16 February 2005 - 06:45 PM
sounds like a glasspack is what you need.
#4 4WDFrenzy
4WDFrenzy
    Certified Subaru Nut
  • 857 posts
Posted 16 February 2005 - 06:47 PM
Well I know that a catalytic converter(high-flow or normal) will muffle alot of the exhaust sound. The only problem with this is, it will restrict your exhaust a bit. Adding a couple of resonators in line before the muffler should help to mellow the exhaust note to a more tolerable level. I hope this helps you.
Patrick
#5 NoahDL88
NoahDL88
    Elite Master of Cookies
  • 4,271 posts
  • Everett, WA, USA
Posted 16 February 2005 - 06:48 PM
From what i've heard, Flowmasters... not so much, try a Dynomax, they flow much better.
#6 Do It Sidewayz
Do It Sidewayz
    Subaru Fanatic!
  • 464 posts
  • Toronto, Ontario
Posted 16 February 2005 - 07:04 PM
flowmasters sound like crap on a turboed car.
#7 4WDFrenzy
4WDFrenzy
  • 857 posts
Posted 16 February 2005 - 07:07 PM
I have to agree with Noah(hope the name is right) on this one. Dynomax mufflers are great sounding and they do flow well. If you really want to quiet it down, go to the nearest O'Reilly autoparts store, ask them to see the Walker Muffler catalog. From what I can find, Walker makes some of the quietest, yet high flowing mufflers. They are kind of moderately priced. If you get a chance to, go and check them out.
#8 tizzle
tizzle
    Subaru Nut
  • 628 posts
  • Bellingham
Posted 16 February 2005 - 07:43 PM
Cool, thanks guys. I'm going to go to a different shop than the one I went to, because that guy is a tweeker( but he does good work) and see if I can get a dynomax or walker.
#9 WJM
WJM
    SUBARU
  • 7,828 posts
Posted 16 February 2005 - 07:56 PM
thats EXACTLY what brings the boxer sound back and takes away all the annoying-ness of the stright pipe sounds.
#10 tizzle
tizzle
    Subaru Nut
  • 628 posts
  • Bellingham
Posted 16 February 2005 - 08:01 PM
#11 subyrally
subyrally
    Trust your Turbo-Lust
  • 2,893 posts
  • frederick, md
Posted 16 February 2005 - 08:06 PM
i have a cherry bomb turbo II mufler on my rx, lots of bass in it and not to loud. granted, its bolted to the stock exhasut and theres a leak in teh pipes.
#12 tizzle
tizzle
    Subaru Nut
  • 628 posts
  • Bellingham
Posted 16 February 2005 - 08:25 PM
WJM's car does sound incredible in those Dragon tales video clips..hmm
#13 gravelRX
gravelRX
    Driven with both feet.
  • 885 posts
  • Roanoke, VA
Posted 16 February 2005 - 08:46 PM
There are different types of Flowmaster mufflers. What series Flowmaster did you put on your car? Choosing the wrong series may be your problem.
I have 2 1/2" exhaust from the turbo, high flow catalytic converter, and a Flowmaster on my car and it doesn't sound like a Toyota pick-up.
Will heard it at an autocross in Radford, Va. maybe he has some insight.
Jay
#14 tizzle
tizzle
    Subaru Nut
  • 628 posts
  • Bellingham
Posted 16 February 2005 - 08:59 PM
honestly, I don't know what series it is, the guy installed it for me.
#15 WJM
WJM
    SUBARU
  • 7,828 posts
Posted 16 February 2005 - 09:11 PM
Header is what makes a subaru sound like a subaru..even with the exh i had for a long time...catless...but under the stock shells...it sounded great and was quiet.
with the TWE's...the exhaust flows PROPERLY...and with a larger diameter...its jsut plain LOUD and with the tuned lenght header, the boxer sound goes away if there isnt anything to take away the high pitched junk out of the sound.
#16 tizzle
tizzle
    Subaru Nut
  • 628 posts
  • Bellingham
Posted 16 February 2005 - 09:17 PM
If I installed a glasspack, it would most likely have to sit in front of the rear axle, right?
#17 NoahDL88
NoahDL88
  • 4,271 posts
  • Everett, WA, USA
Posted 16 February 2005 - 09:32 PM
the glasspack on my 80 is after the axle, works out fine.
#18 WJM
WJM
    SUBARU
  • 7,828 posts
Posted 16 February 2005 - 10:06 PM
Yeah.
#19 4WDFrenzy
4WDFrenzy
  • 857 posts
Posted 17 February 2005 - 02:03 AM
Or you could have it mounted where the #2 stock catalytic converter would go. If I ever decide to go catless and get a test pipe, or straight pipe if you will, then I will replace it with another resonator(large internal dia. glasspack) like the one that is already on the car.
#20 WJM
WJM
    SUBARU
  • 7,828 posts
Posted 17 February 2005 - 06:48 AM
I would put the glass pack at the back where the muffler should go...
WHY?
Because there it will catch all the resonating high pitch stuff and it will sound great.
#21 subyrally
subyrally
  • 2,893 posts
  • frederick, md
Posted 17 February 2005 - 06:54 AM
if you really want the boxer rumble, look into "tuned length" headers, not equal length. tuned means that one side is exactly twice the length as the other, makes the same flow as an equal length but give it the different sound.
#22 JWX
JWX
    Lonely driver
  • 3,073 posts
  • Atlanta
Posted 17 February 2005 - 12:56 PM
the TWE stuff is tuned length
#23 WJM
WJM
    SUBARU
  • 7,828 posts
Posted 17 February 2005 - 01:14 PM
Equal length will take the boxer away. Tuned length is actaully TUNED to the engine's exhaust pulses, and will not nessisarily take or bring the boxer sound. With a stright pipe, the Tuned length TWEs will take the boxer sound away. The Un-equal length stock headers on all subarus is what causes the boxer sound. The borlas are semi-tuned pipes that are better than stock but are still 50% crap....and mostly dont fit right, and give the boxer sound a grumble with the right cats and cat back.
#24 MilesFox
MilesFox
    Catch this Fox!
  • 10,686 posts
  • Madison/Milwaukee, WI
Posted 17 February 2005 - 01:16 PM
what i would do is go with a cherry bomb or no muffler at all
what i find to be ideal is the glass pack at the downpipe flange and stright pipe out the back. the glass pack will give a deep mellow sound and the pope back will take the sound out from under the car, and reduce the pulsing sounds
#25 gravelRX
gravelRX
  • 885 posts
  • Roanoke, VA
Posted 17 February 2005 - 01:43 PM
How about some sound clips?
What sounds good it definately a subjective proposition.
Jay
