00 Legacy GT ECU code deciphering (Please help!)
My check engine light just came on at about 82K miles. I had a 93 Legacy that had a different method of checking engine codes and couldn't be read by a code reader. Are the newer models the same way or can they be read by a code reader? Also, saw something mentioned here about O-rings in the valve covers that keep engine oil out of spark plug holes. Any other info on those, as I have oil leaking around spark plug wires too.
Okay, did some searching and found I could have the code read. Took it to my local Autozone and the results are as follows:
P04020
Catalyst system efficiency for bank 1 is below threshold for the current engine operating condtions.
Can someone translate this for me?
Anyone?
Seeing is believing. Mine were replaced under an extended warranty. Not sure of the cost. I guess they had to do valve cover gaskets and the spark plug seals at the same time.
  • 1 month later...
Like it was explained above, it could be a lot of things, need to test O2 sensors, cat, or even exhausts for leaks, if you want to do it yourself, get yourself a factory manual.
Also, this should be covered by federal emission waranty, check if you are still covered.
You can also reset the code and hope it wont come back.
