ea82 ea82t clutch differences
11 replies to this topic
#1 LPGsuperchargedBrumby
    Fully retarded and low on compression
  • 663 posts
  • Dunedin, NZ
Posted 18 February 2005 - 04:14 AM
is there any difference between the clutchs from a N/A ea82 and a ea82turbo?
#2 vanagonfan
vanagonfan
    New User
  • Pip
  • 3 posts
  • Sacramento
Posted 18 February 2005 - 03:33 PM
That is my question exactly.... I ordered a complete clutch kit from ebay for a 1.8 turbo and the seller (a clutch reseller) told me that the 4WD loyale non turbo and the 1.8 turbo used the same clutch. I'll find out in a few days.
#3 LPGsuperchargedBrumby
  • 663 posts
  • Dunedin, NZ
Posted 18 February 2005 - 04:14 PM
i would rather like to know as im leaveing in about an hour to drive 150 miles to pickup a EJ-unknown at this stage, if its a ej18 or ej20 n/a then i could probibly get away with the clutch i've got now (ea81) and a grippier clutch disc however if it is turbo ej20 or an ej22 i think im gonna need some more bite
but hey the ej donk is free so im not complaining
#4 calebz
calebz
    Andys Coupe killed my cat
  • Administrator
  • 7,547 posts
  • Tacoma
Posted 18 February 2005 - 05:04 PM
There are 2 sizes for the EA82
7-7/8th 2wd
8-7/8th 4wd and all turbo
#5 MilesFox
MilesFox
    Catch this Fox!
  • 10,686 posts
  • Madison/Milwaukee, WI
Posted 18 February 2005 - 05:07 PM
all 5 spd 4wd uses the same clutch disc, this includes single range, dual range, turbos and full time also. supposedly awd ej clutches are the same
i do know for a fact that ej and ea fwd 5spds use the same disc
#6 ballitch
ballitch
    Certified Subaru Nut
  • 1,000 posts
  • Salem, OR
Posted 18 February 2005 - 08:43 PM
do the EA82 and EJ motors use the same style Pressure Plate, with the same bolt pattern? would like to know, they look alot alike, throwing it out there to the wolves.
~Josh~
#7 RickOregon
RickOregon
    USMB Regular
  • PipPipPip
  • 95 posts
  • Burns, Oregon
Posted 18 June 2005 - 02:00 PM
Hey LPGSuperChargedBrumby --
You and vanagonfan probably know the answers to your question by now, but I thought I'd offer some additional input for what it's worth.
If part numbers are any indication, the clutch sets at ThePartsBin.com for a N/A ea82 and a ea82turbo are exactly the same. Which would seem to confirm what MilesFox and calebz say regarding clutch disc interchange.
I've just started looking for a clutch kit to install when we replace the 5sp tranny in our son's '87 4x4 5sp 1.8L GL-10 turbo wagon [with 4x4 engage pushbutton on the shift lever] and found two clutch sets at ThePartsBin.com: $166.83 for Japan/OEM or $148.38 for Japan/Paruaut
Here's ThePartsBin link to the clutch kit page for the '87 turbo wagon:
http://oem.thepartsb...part=Clutch Kit
And here's link to clutch kit for our '86 carbed 4x4 5sp 1.8L GL wagon:
Note the part numbers, pictures, and prices are all the same.
I also found that the clutch kit part numbers are the same for both these cars at Autozone.com.
I'm concluding the release bearings, pressure plates, and discs are the same for both cars. But then maybe I'm getting a bit senile these days... 8-)
Josh [ballitch], you might be able to find an answer using a similar "separate model part search" approach at your favorite online source... just a thought.
Later, Rick
PS: Have any of you purchased a clutch kit from either ThePartsBin.com or Autozone.com? How are they? Pretty good? Do they include the pilot bearing? Release bearing clips?
I looked at AutopartsGiant, which often has lowest parts prices, but couldn't make head nor tails of their clutch kit listings - confusing... to me, anyway.
#8 LPGsuperchargedBrumby
  • 663 posts
  • Dunedin, NZ
Posted 18 June 2005 - 06:17 PM
thanks for the info, as it happens i've been too busy with work to much time into my motor swap and i haven't got the clutch parts i need yet(apart from the fly wheel) so some definitive part #'s is all good.
ohh and i haven't bought any thing from the the partsbin or autozone coz the shipping to here would kill any price advantage.
#9 bgd73
bgd73
    Banned - WARNING! Disregard EVERYTHING posted by this user
  • Banned
  • 1,210 posts
  • Concrete Glacier
Posted 20 June 2005 - 08:56 PM
why the full inch difference noted for the 4wd and 2wd?
If the difference is real, could a 2wd take the bigger clutch?
#10 Pictzie
Pictzie
    New User
  • PipPip
  • 23 posts
  • charleston
Posted 20 June 2005 - 10:04 PM
I do know that the input shaft is a different size and spline count between the 2wd and 4wd 5spds, and the pilot bearing is different. The flywheel seems to be the same though(If I remember right....).
I learned that the hard way($$$$).
Don
#11 archemitis
archemitis
    guy smiley
  • 3,554 posts
  • the big minnie
Posted 20 June 2005 - 10:26 PM
the only differenent clutch disc for the big ea82 disc is the xt6. it fits the same but it has two extra springs, and they are beefier than the 4 cylinder discs.
i think the pressure plate is what gives the xt6 clutch the real holding power. the extra springs on the disc, just soak up more of the big motors inertia when letting the pedal out.
#12 lagwagon
lagwagon
    USMB is life!
  • 157 posts
Posted 21 June 2005 - 11:08 PM
I just put in a new clutch on Saturday. I noticed it said turbo clutch on the box, so I asked my mechanic if it would still work and he said yes and it would be a little stiffer. Well I know it works but I can't tell a difference.
