half shaft replacment tools?
Nothing needed for the axle. Just pull it out. The inner joint, you need a pin punch to drive out the pin. The balljoint does not need to come out completely. Just pull the bottom strut bolt, drop the torsion bar link and you can pry down the A-arm. That way you do not have to get a new alingnment.
Later, Larry
Later, Larry
yup that's how i've done it before
