Attn: Tin Soldier (or anybody with redrilled 6 lug rims)
15 replies to this topic
#1 Guest_Snowman_*
  • Guests
Posted 22 July 2003 - 04:45 PM
I'm currently having wheels from a chevy LUV truck redrilled to fit my soob. Here are a few questions that I have.
In redrilling the rims, how did you get the new holes lined up just right? Or can they be not quite perfect and still be OK? My fabrication guy thinks this could be problematic, though we have turned out one rim that does bolt up. We are concerned that the slight slotting of the two new holes that had to be done to line it up right has weakened it.
What size of tires are you running,and are you having any clearance problems? I think the tires that were on the rims when I grabbed them from the side of the road are 205/70R14 or something close to that.
Any other issues that you had in mounting these wheel up?
Any help is appreciated. Thanks.
#2 Guest_Sweet82_*
  • Guests
Posted 23 July 2003 - 02:36 PM
Have you seen this...8o
Seems as though he did a pretty good job. It sounds straight forward enough:rolleyes:
I have been thinking about doing the same...
Good luck,
82 Hatch, soon to go off-road permantly:evil:
01 Forester, off-road ocasionally...;)
#3 Guest_Snowman_*
  • Guests
Posted 23 July 2003 - 08:27 PM
I had considered that, but I may be running my snow tires on standard subaru rims, at least for a while, so I need to stick with 4-lug.
The problem may be solved for me. My fabrication guy said that any major machine shop will have a tool called a turntable which can drill two new holes perfectly. No screwing around with patterns or anything. Just perfect holes. I just have to wait about a month until I'm in anchorage to do it.
#4 Guest_uhohru_*
  • Guests
Posted 23 July 2003 - 09:37 PM
Does anyone sell these 6 lug re-drilled hubs?
#5 Guest_sandhappy_*
  • Guests
Posted 23 July 2003 - 11:49 PM
Hi there I have a jig for redrilling the rims with a custome made center punch. I run 15"x10" wheels with 31" tires and I jump and beat the crap out of it. It has held up fine so far. Email me if you want detailed directions...
#6 Guest_uhohru_*
  • Guests
Posted 24 July 2003 - 01:22 AM
Whats the email address?
#7 Guest_uhohru_*
  • Guests
Posted 24 July 2003 - 06:44 PM
#8 Guest_Snowman_*
  • Guests
Posted 24 July 2003 - 07:56 PM
How about grabbing a hub off of a junked car, knocking two opposing studs out of it, bolting it up to the rim with the remaining studs, and using that as a guide for drilling?
#9 Guest_offroadsubaruguy_*
  • Guests
Posted 24 July 2003 - 08:27 PM
i was thinkingthe same thing snowman.......but im prolly gonna do the hubs instead, i feal a little safer that way.......pls it just looks cool :D :D :D
#10 Guest_sandhappy_*
  • Guests
Posted 24 July 2003 - 08:37 PM
my email is sandhappy1@aol.com
#11 Guest_calebz_*
  • Guests
Posted 24 July 2003 - 08:57 PM
You asked about tire size as well..
I am using 14 inch pugs.. they are straight bolt on. as far as tires, go I found that the best compromise between fender clearance and size was 185-75-14. I know that there are others running bigger tires, but I found that with no lift, anything larger, and I did try 2 larger sizes.. caused rubbing issues
#12 Guest_Tin Soldier_*
Guest_Tin Soldier_*
  • Guests
Posted 25 July 2003 - 02:44 PM
Hey, SOrry it took me so long to see this message I have been real busy. On drilling 6 luggers. It's pretty darn simple. Just go square in the middle of two holes and drill a new hole. Mine are very messy (burned them with a touch) :) I just tighten down the two good holes first real tight. Then I put the lugs on the junky holes. I would not think they would be that weak. They were made for a truck for goodness sakes. :)
Anyhow, I have jumped my suby over a bridge twice today in fact and run through all kinds of rough stuff with no problems. I recomend keeping an eye on your lugs though. Mine came loose the first day and I had to really crank them down. Haven't been loose since (3 months now).
#13 Guest_Snowman_*
  • Guests
Posted 25 July 2003 - 09:25 PM
Thanks for the info. One more question: What size of tires are you running and do they rub at all offroading?
#14 Guest_Adam N.D.J._*
Guest_Adam N.D.J._*
  • Guests
Posted 26 July 2003 - 03:49 AM
I had chevy 15" rims redrilled for the 4 lug. The rims were off a K-5 blazer and had raises where the holes were to be drilled. Blanks so to speak. They've held up for 2 years now with no problems. I had a spare hub laying around and used it as a guide for drilling out the rim. Catch ya Laters.
#15 Guest_uhohru_*
  • Guests
Posted 26 July 2003 - 06:07 PM
I have decided to redrill my rims...
how do i post pictures?
#16 Guest_Tin Soldier_*
Guest_Tin Soldier_*
  • Guests
Posted 05 August 2003 - 02:11 PM
I have 215/70r14 's and they rub bad with no lift
I still had to cut my front fenders after I got the lift.
