Bushing Q
3 replies to this topic
#1 75skunkaroo
    Gimmie Shock Treatment
  • 587 posts
  • Central Point Or.
Posted 21 February 2005 - 12:35 PM
ok, to make a long story short, the '75 has had a bad vibration anywhere over 35mph, caused by a bent wheel, or so i thought. wham! dead wrong. the front mount for the rear diff has bad bushings. is there anyway of pounding the old ones out and finding 'new' ones? i'd replace the mount itself, but it's a little tricky to find. looks like the upper control arm for the rear end of a '69 chevelle.
thanks all
#2 75skunkaroo
  • 587 posts
  • Central Point Or.
Posted 24 February 2005 - 03:22 PM
i don't think the car likes having to be 2wd to stop the vibrations.
would the window weld stuff work good to fix this problem?
#3 Ross
    Can't be bothered
  • 1,865 posts
  • Christchurch, New Zealand
Posted 24 February 2005 - 11:11 PM
most bushings can be replaced, contact your dealer and ask if there is a repalcement available. If not, a parts shop could probabyl find one similar if you take the old one out first
#4 MorganM
    Do you Subaru?
  • 8,390 posts
  • TwinCities
Posted 25 February 2005 - 09:35 AM
Check out the Marketplace forum under the bushing group buy in. The company that makes those bushings might have the one you are looking for.
