Mystery wire - engine ground?
5 replies to this topic
#1 Scottbaru
    Eat, Live, Breath Subaru
  • 312 posts
  • Holland
Posted 21 February 2005 - 07:15 PM
In my first venture under the hood of this Subaru, I found what looks like an engine ground wire laying loose on top of the tranny, coming from the left side. It's heavy gage and black, the end has a bracket with a hole crimped to it. I'm not sure where it's supposed to go, I put it under the upper nut for the starter. The bracket looked purposeful, but there was no other obvious place to attach it. There are a couple threaded holes on top of the tranny, but they didn't look recently used, and this probably happened recently when the clutch went in.
#2 ballitch
    Certified Subaru Nut
  • 1,000 posts
  • Salem, OR
Posted 21 February 2005 - 07:27 PM
that i believe is the ground for the starter as you said, the big red one is your power, make sure both are connected really well.
#3 Scottbaru
  • 312 posts
  • Holland
Posted 21 February 2005 - 08:15 PM
It's tight, with plenty of copper anti-sieze, thanks.
#4 bearbalu
    USMB is life!
  • 182 posts
Posted 21 February 2005 - 10:49 PM
On manual transmissions, I think it is supposed to go in a bracket that goes on the transmission mount bolt on driver side.
#5 Setright
    Elite Master of the Subaru
  • 3,176 posts
  • Denmark
Posted 22 February 2005 - 02:18 AM
Yes, it bolts onto the transmission housing.
#6 Tiny Clark
Tiny Clark
  • 807 posts
  • Germany
Posted 22 February 2005 - 02:51 AM
I doesn't make a difference where it's connected really, as long as it's on a beefy piece of metal on the drivetrain assembly.
I helped a guy fix a starting problem on an old Fiat. He told me his clutch cable would glow red when he was trying to start his car, and it would turn over real slow.
Got underneath, and found the big ground wire with both ends hooked to the chassis!
Hillarious!! :)
