#%$^@&*&* Digital Dash
5 replies to this topic
#1 Dr. RX
Dr. RX
    Elite Master of the Subaru
  • 9,984 posts
  • Sammamish, WA
Posted 27 August 2003 - 05:38 PM
In case you didn't get it, I HATE DIGITAL DASHES!!!!! :temper: First it was the temperature guage, now it is the fuel guage. With a full tank of gas, sometimes it reads empty, somethings 2 bars, somethings 3 bars, something two bars from the top, and it changes every time that I turn the key on. :banghead: It is a good thing the odometer still works, I know about how far it goes on a tank of gas, so I re-fill when it gets close to that mileage. Has anyone else had this problem and found a fix???
#2 Subi81
Subi81
    1000+ Super USER!
  • 1,009 posts
  • Ventura, Ca
Posted 27 August 2003 - 06:52 PM
Had a problem with my gauge but it turned out to be the sending unit was out of calibration.
Maybe the contacts on the sender are messed up? It is a lot easier to pull the sending unit than the digimondash.
Good luck!
#3 Flowmastered87GL
Flowmastered87GL
    WCSS Drunk
  • 6,269 posts
  • Portland, Oregon
Posted 28 August 2003 - 02:09 AM
my $350 86 that I had you swap the engine on... had the SAME problem... sometimes the gas light would come on AND the trip computer would read 0 miles after a fill up :cornfuzz:
Solution... I sold the car and told the guy to trust ONLY the odometer and the analog temp guage :clap:
#4 beauregaardhooligan
beauregaardhooligan
    Subaru Fanatic!
  • 424 posts
  • Greenville, SC
Posted 28 August 2003 - 05:37 AM
Sounds like goofy contacts.
Try cleaning them up nice and shiny.
Humidity may be the culprit. Maybe some di-electric grease.
One of the digis I had in my '84 would act like that when it rained.
#5 CIS Subaru
CIS Subaru
    User Awaiting Email Confirmation
  • 1,992 posts
  • Columbus, OH
Posted 30 August 2003 - 07:48 AM
I assume this is on the '86 GL-10??
If so, it seems that the '85-'86 LCD digi-dashes had a problem with the solder joints for the fuel and temp gauges.
I fixed my temp gauge by pulling the cluster and holding a soldering iron on the temp sender pin on the back. I sold the car soon after, so I'm not sure how long the fix lasted.
Naturally, the correct solution would be to tear the cluster apart and properly solder the pins, but that would be quite a large job.
You might consider swapping an '87+ LED digi-dash in its place as they are much more reliable, but I don't know if the wiring would be the same or not.
#6 Dr. RX
Dr. RX
  • 9,984 posts
  • Sammamish, WA
Posted 30 August 2003 - 10:36 AM
CIS, actually both of my Subarus have digital dashes, but you are right, it is the 86. I know about the solder trick, but never tried it. I've thought about that 87+ digi-dash, but there were quite a few changes to the interior between 86 and 87, so like you, I'm not sure it would work.
