Alright...
So what's the skinny on drilling out the 6-lug wheels to fit the 4-lug Subaru bolt pattern??
I've got easy access to plenty of 6-lug Toyota wheels(larger center hole than chevy 6-lug).... who's got the details PLUS pictures on doing this?!?!?
Welcome to Ultimate Subaru Message Board, an unparalleled Subaru community full of the greatest Subaru gurus and modders on the planet! We offer technical information and discussion about all things Subaru, the best and most popular all wheel drive vehicles ever created. We offer all this information for free to everyone, even lurkers like you! All we ask in return is that you sign up and give back some of what you get out - without our awesome registered users none of this would be possible! Plus, you get way more great stuff as a member! Lurk to lose, participate to WIN*!
* The joy of participation and being generally awesome constitutes winning ** Not an actual guarantee, but seriously, you probably won't regret it! Serving the Subaru Community since May 18th, 1998! |
How 2's for 6-lug drill out for 4-lug!!
Started by
Toyofast
, Aug 27 2003 08:14 PM
6 replies to this topic
#1
Posted 27 August 2003 - 08:14 PM
#2
Posted 27 August 2003 - 09:28 PM
Since I am going to do this in the near future, I have done some research on this topic. The two methods that I am currently looking at are: Taking the rims to a machine shop, where they can put it on a machine that can turn that out in five minutes. I am also thinking about grabbing a brake drum, pounding out two opposing studs, bolting it up to the rim with the existing two studs, and using that as a guide. I'm sure there are other good ways to do it as well, which I would love to hear about.
#3
Posted 27 August 2003 - 09:49 PM
I did mine by the second method you posted basically. I used a front hub with the diagonal studs knocked out. bolted it up to the Chevy 6 lug wheel, then from the back, used the hub as a drill guide. Just used my half inch hand held drill. be sure to have new bits handy, and use some cutting oil. helps if you are strong when doing it this way... I had some sore wrists from having the bit catch many times, and get the drill ripped out of my hands... nothing broken though...
then after the holes are drilled, use a die grinder to put the bevel on the holes from the front...
#4
Posted 27 August 2003 - 10:04 PM
is there a particular wheel that works better than others? foriegn- domestic. I too have a assortment of 6 lug wheels to choose from
#5
Posted 27 August 2003 - 10:27 PM
just depends on how much you want the wheels to stick out... the Chevy wheels in the pic above set out quite a bit... don't know for sure the width of them, but they've got 30x9.50x15 tires on 'em... I think they set out about 4" past the cut fender
the toyota rims Qman has, set nicely...
#6
Posted 28 August 2003 - 01:29 AM
I am currently planning on using 14" Chevy LUV truck rims. They may cause the tires to stick out too much, which could be an issue since my car has no lift. So far, the rims with the closest-to-stock offset that I have seen were on an early-nineties Isuzu pickup. If I can score a set of those cheap I'll use them, but since the chevy rims were free (found an abandoned truck in pieces), I'll probably just make those work.
#7
Posted 28 August 2003 - 02:01 AM
I am going to re-drill EA81 front disks and EA82T rear disks for my 82 brat very soon.... I am a bit scared though as the rotor bolts on VERY close to where the holes will be drilled.. I am going the 6 lug route... I am running Dodge D50 / Mitsu rims with a toyota/nissan full size spare (whatever 15" rim I find cheap)
