Welcome to Ultimate Subaru Message Board, an unparalleled Subaru community full of the greatest Subaru gurus and modders on the planet! We offer technical information and discussion about all things Subaru, the best and most popular all wheel drive vehicles ever created. We offer all this information for free to everyone, even lurkers like you! All we ask in return is that you sign up and give back some of what you get out - without our awesome registered users none of this would be possible! Plus, you get way more great stuff as a member! Lurk to lose, participate to WIN*!
* The joy of participation and being generally awesome constitutes winning ** Not an actual guarantee, but seriously, you probably won't regret it! Serving the Subaru Community since May 18th, 1998! |
First post cry for help!
Started by
heisenbergup
, Mar 06 2005 08:49 PM
9 replies to this topic
#1
Posted 06 March 2005 - 08:49 PM
1999 outback starts, but won't keep running. After initially going to idle rpms in a few seconds rpm's drop and it quits running. If I give it gas after it starts and try to hold rpm's steady the same happens: RPM's drop and it quits running. Has anyone had this problem and know what is malfunctioning. Thanks.
#2
Posted 06 March 2005 - 08:56 PM
is it throwing a check engine light?
#3
Posted 06 March 2005 - 09:21 PM
Did anything unusual happen prior to the problem?
Anyone under the hood before, to do work or check oil, etc.?
Driving in a lot of snow or rain recently?
When it first starts and runs, is it smooth RPM or stumbling before it quits?
Could be any number of things from a loose connection of a hose or wire under the hood to a clogged fuel filter or just a dirty air filter.
#4
Posted 06 March 2005 - 11:51 PM
I replaced the air filter the day before problem started. I also checked the oil level and the EGR valve. When it starts up it runs smooth before quitting.
#5
Posted 06 March 2005 - 11:53 PM
It is not throwing a check engine light.
#6
Posted 07 March 2005 - 12:04 AM
did you check to make sure all hoses an vac lines connected??
#7
Posted 07 March 2005 - 12:55 AM
Ditto... check all hoses ...
Now do it again.
#8
Posted 07 March 2005 - 02:15 AM
This happened to me once, after an air filter change. I accidentally disconnected the IAC hose, which is out of sight underneath the main air intake pipe. Get a flashlight and hunt it down under your bonnet.
Also, check you air filter box, it might not be closed properly.
#9
Posted 07 March 2005 - 06:22 AM
agree, sounds exactly like the iac hose. very easy to unhook it doing the air filter
#10
Posted 07 March 2005 - 01:53 PM
Thanks to all who responded. It was a hose that came loose while manipulating the air filter housing to replace the filter. Problem fixed. Thanks again.
