ben123 Posted March 7, 2005 Share Posted March 7, 2005 I came home the other night via Taxi and as I walked up my front steps I clicked the lock on the remote for my '99 Forester. To my surprise the horn honked and the 4-ways flashed. Normally only the 4-ways go off (no horn). To other '99 owners, when you lock with the remote which happens 1 horn + 4 ways 2 only 4-ways Do I have a bad elec connection somewhere? Quote Link to comment Share on other sites More sharing options...
Cougar Posted March 8, 2005 Share Posted March 8, 2005 I think you can program the system to sound the horn or not sound it. It appears you will need to reprogram the system. Check your owners manual for details on doing this. Quote Link to comment Share on other sites More sharing options...
gtwagon Posted March 8, 2005 Share Posted March 8, 2005 I came home the other night via Taxi and as I walked up my front steps I clicked the lock on the remote for my '99 Forester. To my surprise the horn honked and the 4-ways flashed. Normally only the 4-ways go off (no horn). To other '99 owners, when you lock with the remote which happens 1 horn + 4 ways 2 only 4-ways Do I have a bad elec connection somewhere? From 2000 Outback Owner's Manual: Selecting audible signal operation Using the horn, the system will give you an audible signal when the doors lock and unlock. If desired, you may turn the audible signal off. To turn the audible signal off, simultaneously depress “LOCK/ARM” and “UNLOCK/DISARM” buttons for more than two seconds. The horn will sound two times to inform you that the audible signal has been turned off. To turn the audible signal on, simultaneously depress “LOCK/ARM” and “UNLOCK/DISARM” buttons for more than two seconds. The horn will sound one time to inform you that the audible signal has been turned on. Hope this helps........ Quote Link to comment Share on other sites More sharing options...
