front end vibration
3 replies to this topic
#1 Guest_scubabike420_*
  • Guests
Posted 09 March 2005 - 03:55 PM
I have a front end vibration and I believe I have found the source of the problem. When I grab the tie rod on driver's side I get some play on the inner end. I see a long boot on this end. What's under this and how hard/expensive is it to replace?
'95 Legacy Wagon
#2 Subie Gal
Subie Gal
  • 1,451 posts
  • WA
Posted 09 March 2005 - 06:26 PM
there's a snap clip hidden under there
it's not a 'fun' swap by any means but it totally doable.
part should cost $20-30ish
contact me if you want to verify
i can get you a quote with 20% off...
parts are new from subaru
good luck!
#3 Guest_scubabike420_*
  • Guests
Posted 10 March 2005 - 08:31 AM
Is it normal for this clip to allow play in the tie rod?
#4 Setright
    Elite Master of the Subaru
  • 3,176 posts
  • Denmark
Posted 11 March 2005 - 05:05 AM
A little play, up and down, is not exactly optimal, but it's not dangerous and won't cause vibration.
Play out and in, is someting to worry about, and since wheel direction control suffers, this could cause vibrations.
Which way can the rod move?
