Starting Problems Again
4 replies to this topic
#1 dale47
dale47
    New User
  • PipPip
  • 25 posts
  • Monongahela
Posted 10 March 2005 - 02:54 PM
I posted a thread about my 96 legacy not starting a couple weeks ago. This morning it was the same thing again.crank..crank..crank. The last time it happened I removed a plug wire from the coil pack and plugged in a sperate test wire to see if I was getting any spark. The car fired right up !!. This morning after not starting for 15 minutes, I popped the hood, disconnected the same plug wire from the coil pack and I'll be damned if it didn't fire right up. I shut the car off..reconnected the wire and it's been running fine all day. Anybody have any idea whats going on here. Its a 2.5.
#2 A_DuB
A_DuB
    USMB Regular
  • PipPipPip
  • 44 posts
  • Leavenworth
Posted 10 March 2005 - 08:10 PM
Sounds like you need a new plug wire:drunk:
#3 dale47
dale47
    New User
  • PipPip
  • 25 posts
  • Monongahela
Posted 11 March 2005 - 11:55 AM
If the plug wire was bad, wouldn't it miss-fire ?
#4 Cougar
Cougar
    Elite Master of the Subaru
  • 6,563 posts
  • Anchorage
Posted 11 March 2005 - 02:23 PM
You may have an intermittant connection at the coil pack. I doubt that one plug wire is bad and you just happened on it. The problem may be internal to the coil also.
#5 dale47
dale47
    New User
  • PipPip
  • 25 posts
  • Monongahela
Posted 11 March 2005 - 02:54 PM
Does anyone think I may be tricking the crank sensor. By diconnecting the plug wire it see's an open cylinder ?
