pyromanic Posted March 11, 2005 Share Posted March 11, 2005 Hey, is it safe to assume that since my 85 is 20 years old, and visibly sagging in the rear I think, that it would be ok to take the rear strutts up one notch? (I see that they are still on the lowest setting.) Which was Fuji thinking when they made them adjustable. To accomadate heavier loads, or to be adjusted for wear and time? Or something else I'm missing? And lastly, does adjusting the rear struts up affect fron castor, camber, or steering in any way? (I get that keeping the rear axles straighter makes them last longer) Thanks Pyro Quote Link to comment Share on other sites More sharing options...
Ross Posted March 11, 2005 Share Posted March 11, 2005 yep, move em up. Steering & so on should be all but unaffected. Quote Link to comment Share on other sites More sharing options...
dragonwingsubaru Posted March 11, 2005 Share Posted March 11, 2005 dont mean to sound stupid but how the hell do you adjust the rear coilovers?, ok just noticed that you had said struts or these things supposed to have struts in the rear? ive seen paople mention a few times how the 85 suspension is adjustable but ill be damned if i can figure out how to do it!! Quote Link to comment Share on other sites More sharing options...
Ross Posted March 11, 2005 Share Posted March 11, 2005 theyre not really struts, they are coil-over shocks. Not all had the adjustment i don't think, but the ones the did have a collar that the spring mounts on. It sits on pins, and can be rotated to sit in three different positions. Thats what i remember anyway, its been a while since ive looked at one. Quote Link to comment Share on other sites More sharing options...
dragonwingsubaru Posted March 11, 2005 Share Posted March 11, 2005 thanks for the info ross, ill take another look at mine today to see if i can adjust them at all. i know that the suspension stuff like the struts and coilovers look completely different from the ones that i pulled off my 87 Quote Link to comment Share on other sites More sharing options...
pyromanic Posted March 11, 2005 Author Share Posted March 11, 2005 thanks for the info ross, ill take another look at mine today to see if i can adjust them at all. i know that the suspension stuff like the struts and coilovers look completely different from the ones that i pulled off my 87 Hey dragonwingsubaru, what do you mean by custom spit hood, and shaved emblems? I'm still learning the difference between stuff like coilovers and strutts! I'll get there eventually. Pyro Quote Link to comment Share on other sites More sharing options...
dragonwingsubaru Posted March 11, 2005 Share Posted March 11, 2005 pyromaniac what i mean by that stuff is shaved emblems means remove all emblems and fill in what needs to be filled and made smooth. and on the custom split hood i mean to basically cut it in half and have both halves open to a different side, if you are haveing trouble visualizing it look at the need for speed underground 2 game at the split hood section its gonna be the one that splits to the dr and pass side. dont worry about understanding the stuff yet it took me a long time to understand stuff, but i will admit i still have alot to learn!! these forums are a great place to learn, there is always a few gurus in every forum that can help you learn stuff. Quote Link to comment Share on other sites More sharing options...
wintersubaru Posted March 12, 2005 Share Posted March 12, 2005 On my 1986 gl wagon all four wheels (front struts rear coilovers ) are adjustable have been all the way up for allmost to years no problems yet. gave me about 1 icch of lift in front and 1.5 in the rear. Quote Link to comment Share on other sites More sharing options...
