Rough Idle
6 replies to this topic
#1 88xt6joe
88xt6joe
    DA WEDGE
  • 358 posts
  • Boise
Posted 29 August 2003 - 09:13 PM
What would be the reason for rough idle after my car get warm its a 1.8 w/FI. It seems like everything else is normal starts great and runs good but doesn't like idling when warm.
Thanks, Joe
#2 GeneralDisorder
GeneralDisorder
    Elite Master of the Subaru
  • 21,922 posts
  • Portland
Posted 29 August 2003 - 09:18 PM
I don't know much about the FI models, but I know that the people here who do will probably need more info - what type of FI do you have? (SPFI, or MPFI). What year is the engine, and what car is it on?
#3 88xt6joe
88xt6joe
    DA WEDGE
  • 358 posts
  • Boise
Posted 29 August 2003 - 09:26 PM
Its a 88 GL wagon 88 model engine w/176,000 miles and I believe it is SPFI but I'm not sure.
JL
#4 GeneralDisorder
GeneralDisorder
  • 21,922 posts
  • Portland
Posted 29 August 2003 - 09:35 PM
Have you checked you ECU (under the drivers dash) for error codes? This can help narrow down the problem if the computer has already detected something strange.
#5 Skip
Skip
    Flatuous Blather
  • Moderator
  • 8,991 posts
  • Latrobe, Pennsylvania
Posted 30 August 2003 - 07:47 AM
Joe, The problem you are having is common on SPFI cars.
The IAC (Idle Air Control) valve wants it's shuttle cleaned.
They have a tendency to get varnish on them and stick.
This control valve is mounted on the front of your throttle body, has a cylinder with wires going to it.
It can be removed and cleaned with carb cleaner.
Hope this helps
#6 88xt6joe
88xt6joe
    DA WEDGE
  • 358 posts
  • Boise
Posted 30 August 2003 - 10:17 AM
Thanks, I'll give that a try today.
JL
#7 88xt6joe
88xt6joe
    DA WEDGE
  • 358 posts
  • Boise
Posted 30 August 2003 - 05:00 PM
Think I got it figured out the top of my cover over the spfi was sunk down in and not getting enough air through. I lifed it up and now it seems to be fine. It was down about an inch and half.
JL
