carlcava Posted March 15, 2005 Share Posted March 15, 2005 I have a 2000 Outback Wagon and would like to remove the radio. Can someone share with me how to do this. Thank you in advance. Quote Link to comment Share on other sites More sharing options...
subie94 Posted March 15, 2005 Share Posted March 15, 2005 well if your radio area is anything like my 94 legacys,it's easy. first pull out an remove the cup holder.you should see two screws that would have been behind were the cup holder went in,remove those and the molding around the radio should come off.before pulling that off remove ashtray or you might have a mess(if you smoke an have ashes in there of course)just about as you have the molding off,your gonna have a wire harness going to the ashtray for the light.easy disconnect.once you have molding around radio removed/on my radio there's about 6 screws holding the radio in(4 in the front,1 on either side towards rear.undo those then carefully disconnect wiring harness from back of radio and remove antenna wire. unless there's a wire i forgot about,you have just removed a radio. this is what mine looked like when i had mine out. hopefully your's is similar Quote Link to comment Share on other sites More sharing options...
