EA82t Crossover pipes Qs
5 replies to this topic
#1 [HTi]Johnson
[HTi]Johnson
    Lifted or Rally? choices.
  • 1,510 posts
  • Coburg, Or.
Posted 18 March 2005 - 12:36 AM
How big is the I.D. (Inside Diameter) of a stock crossover pipe? and what would be the perfect size for a happy medium...you know...not too laggy and pretty good topend?
[HTi]Johnson
#2 rallyruss
rallyruss
    Subaru Master
  • 1,653 posts
  • San Jose CA
Posted 18 March 2005 - 01:43 AM
the narrowest point is aprox 1 1/4" right at the bend to go up to the turbo. I choped that section out and put in a 2" section. posted it back when I did it. also smoothed the ports in and out of the up pipe. runs good but then again I did the TD04 at the same time so who knows what it really did.Posted Image
#3 [HTi]Johnson
[HTi]Johnson
  • 1,510 posts
  • Coburg, Or.
Posted 18 March 2005 - 01:53 AM
OOOH!! Pretty turbo. I was thinking of TRYING to make an equal length crossover pipe...out of 1.5" tube of .095 wall...so that makes it likea little smaller than 1.375"(1 and 3/8th inch)
[HTi]Johnson
EDIT: Oh yeah, the reason I can't make it bigger is because of my resources...everything I have access to is for some heavy duty tube. (I work for an Ornamental Iron company:-p)
#4 rallyruss
rallyruss
    Subaru Master
  • 1,653 posts
  • San Jose CA
Posted 18 March 2005 - 01:57 AM
[HTi]Johnson
that would probably work well. leave the dump into the turbo a bit small to keep speed up. I was looking at the turbo off a 1.8T VW in my garage and it has a tiny inlet but can make some real good power.
#5 garner
garner
    Brat Master Flash
  • 689 posts
  • Vilas, NC
Posted 18 March 2005 - 01:20 PM
Equal length will be a pita unless you have a very tight mandrel bender. I build mine out of stainless weld elbows and straight pipe (from coyote steel)
check it out http://usmb.net/gall...bum290/P6160094
The pipe is 1.5 schedule 80 (i think) the id is 1 5/8 which is too big but it flows like a mo fo
If I were to do it over, I'd go for about 1 1/4 or 1 3/8. reguardless of the id the design is far superior to that pos bathroom plumbing thing they car a header.
garner
#6 TheSubaruJunkie
TheSubaruJunkie
    Subaru Sober since 2010 :(
  • 1,907 posts
  • Sacramento
Posted 18 March 2005 - 08:44 PM
This thread has made me realize just how badly I want a new header...
and a new turbo...
oh... and then I can install my IC :)
-Brian
