Welcome to Ultimate Subaru Message Board, an unparalleled Subaru community full of the greatest Subaru gurus and modders on the planet! We offer technical information and discussion about all things Subaru, the best and most popular all wheel drive vehicles ever created. We offer all this information for free to everyone, even lurkers like you! All we ask in return is that you sign up and give back some of what you get out - without our awesome registered users none of this would be possible! Plus, you get way more great stuff as a member! Lurk to lose, participate to WIN*!
* The joy of participation and being generally awesome constitutes winning ** Not an actual guarantee, but seriously, you probably won't regret it! Serving the Subaru Community since May 18th, 1998! |
Tapping into the Instrument Panel Dimmer
#1
Posted 21 March 2005 - 08:09 PM
I am new to the forum and want to say Hello to everyone. I have been watching for a while and have seen some great threads.
I have a 05 Forester and I just bought and installed a compass (not the LCD in the mirror kind, but the dial floating in a liquid kind.) I have mounted it on the top of the dash in the center. It came with wiring attached to power a small LED light for night use which I have not hooked up yet. I can see where I could tap into the fuse panel and through a switch to make the connection, but wonder if it might be feasible to tap into the dash panel lighting, so that it goes on with the rest of the dash lights.
#2
Posted 21 March 2005 - 08:28 PM
It sounds like you're on the right track. I would wonder if you couldn't get your wires to follow the top of the dash pad at the glass, and press it out of view into the crack there all the way to the A pillar, then down under the dash, along to the wiring harness for the heater controls. Here you could tap into the sources needed without having to stand on your head under the dash trying to find another source. You don't give a year and model so I can't be more specific. Taking the garnishes around the heater controls is not a big deal, if you take your time and don't force anything. Good luck!
#3
Posted 21 March 2005 - 08:44 PM
You can tap into the dash light circuit. Try to find the most convenient light to tap onto.
#4
Posted 21 March 2005 - 09:37 PM
#5
Posted 23 March 2005 - 01:51 AM
If you want to use the dimmer, it's my opinion that you'll have to replace the LED circuit with a 12 volt peanut bulb of some type from Radio Shack.
Does the ligher receptacle have a light ring around it that dims? That may be the easiest place to tap into. There should only be a ground, 12 volts for the lighter, and the lighting wire.
#6
Posted 23 March 2005 - 02:53 AM
Thanks!
Sweden
#7
Posted 23 March 2005 - 07:59 AM
I don't think it is much trouble to get behind the instrument panel. Are you sure that the problem is the gauge and not the sensor or the wiring to the gauge?
#8
Posted 23 March 2005 - 08:24 AM
As cougar said, I would make sure it's the gauge first tho!
#9
Posted 23 March 2005 - 08:32 AM
Keep in mind that an LED doesn't work the same as a light bulb. It may not come on until the dimmer is set to a certain point and the diode junction is "energized", and I don't believe you'll see much dimming action once it is on.
Correct.
One could also use a pulse width modulation (PWM) IC to take the analog voltage from the dimmer circuit and convert it to a variable duty cycle square wave to modulate the brightness of the LED. A programmable microcontroller would be the easiest way to do this.
Another way to do it would be to use an operation amplifier and use the dimmer voltage to modulate the LED current. This would be more difficult but much more elegant.
Some car makers (GM for certain) are now using PWM for dimming, so I wouldn't rule that out. You might just try hooking it up first, because if Subaru is now using PWM dimming it will work perfectly.
#10
Posted 24 March 2005 - 02:56 AM
