Is there a Cam Cover Gasket?
1 reply to this topic
#1 Guest_oregonloyale_*
  • Guests
Posted 15 August 2003 - 01:10 PM
Im replacing the check valve spring and I dont knoe if there is a cam cover gasket to replace or just use some RTV sealent?<img src=http://www.ezboard.com/intl/aenglish/images/emoticons/ohwell.gif ALT=":\">
#2 Guest_GlCraigGT_*
  • Guests
Posted 15 August 2003 - 03:09 PM
Now if I remember right you have an EA82 engine. Sometimes the Valve covers are referred to as Cam covers and there are gaskets for them. But you say you are changing a check valve spring, the only one of those I'm aware of is in the oil pump. The oil pump has 2 seals, one for the shaft and an o-ring known as the Mickey mouse o-ring which goes between the pump and the engine block.
