Squeaky Wheel !!
3 replies to this topic
#1 SubaRube
SubaRube
    Eat, Live, Breath Subaru
  • 256 posts
  • San Leandro, CA
Posted 31 August 2003 - 11:18 PM
When I'm going about 25-35 I hear a squeak coming from my front wheel on the passenger side. It gets alot louder if I let off on the gas. Braking doesn't change the sound. If I throw it in neutral it goes away. Outer CV? I've heard a click a couple of times when it's cranked, but very faint. Boots are fine.
#2 MilesFox
MilesFox
    Catch this Fox!
  • 10,686 posts
  • Madison/Milwaukee, WI
Posted 01 September 2003 - 01:08 AM
could be a loose axle nut, and the rotor is huttin g the outerh caliper frame, the caliper frame will keep the rotor in place.
does the car jerk the wheel or does the tires chirp when downshifting?
if so, that is what an axle will sound like before breaking in the middle of wisconsin
check the front diff oil. use 90 wt gear oill
#3 TheSubaruJunkie
TheSubaruJunkie
    I'M BAAAAAACK!
  • 1,922 posts
  • Sacramento
Posted 01 September 2003 - 01:14 AM
goes away when you have it in nutral??? hrm.
i was thinking it could be a bearing. Maybe put it on jackstands and put the car in gear. See if you can pinpoint the sound with the car sitting still.
But I would definatly check for ripped CV boots, loose castle nuts and brake equipment.
-Brian
#4 SubaRube
SubaRube
  • 256 posts
  • San Leandro, CA
Posted 06 September 2003 - 12:03 AM
Good call SubaruJunkie. Wheel bearing is toast. Thanks to everyone for the responses.:headbang:
