Welcome to Ultimate Subaru Message Board, an unparalleled Subaru community full of the greatest Subaru gurus and modders on the planet! We offer technical information and discussion about all things Subaru, the best and most popular all wheel drive vehicles ever created. We offer all this information for free to everyone, even lurkers like you! All we ask in return is that you sign up and give back some of what you get out - without our awesome registered users none of this would be possible! Plus, you get way more great stuff as a member! Lurk to lose, participate to WIN*!
* The joy of participation and being generally awesome constitutes winning ** Not an actual guarantee, but seriously, you probably won't regret it! Serving the Subaru Community since May 18th, 1998! |
high idle, off shiftpoints
#1
Posted 23 March 2005 - 07:47 PM
A little car history:
My dad gave me the car-while I was moving the tire blew and I had to drive 150 miles on a spare. Also he was driving it on dissimilar tires-all bad things for the tranny. One day it wouldn't move, so on a guess I replaced the tranny filter. The thing was totally clogged. I took it to a tranny place sometime afterwards suspecting the filter had clogged again and they said it was fine. Not that I trust them. I think there is too much fluid in there, but the dipstick just doesn't give a good read. When I filled it I couldn't get it right and the tranny place didn't seem to have better luck.
I just replaced the coolant temp sensor because the check engine light was on-thinking "ah this is all sensor related," but that was not the case. Perhaps the AFM isn't good. There are too many sensors to consider and it's too cold to work on it. But a high idle and high shiftpoints make it unpleasant to drive.
#2
Posted 23 March 2005 - 08:50 PM
The transmission, I'm not too sure, but I do kind of have a question for all you experts. I know with other auto trannies that the fluid doesn't circulate when the car is in park, so if you are letting the car warm up in the morning you can put it in "N" with the e-brake on to warm up the tranny. Guys who snowplow and haul trailers quite often do this after they are done to help cool the trans off. Just a question.
#3
Posted 24 March 2005 - 05:54 AM
#4
Posted 24 March 2005 - 02:44 PM
The square headed screw on top of tranny is brake band adj. for changing shift behavior...Unless you read up on the adj. proceedures indepth it would be best to leave it alone. High idle could be a bunch of things...from an O2 sensor to a tight throttle cable. You didn't state mileage of your car, but my 2.2 with higher mileage doesn't run the same all the time...specially when cold. You should have the OBD-II system in yours. The check engine light needs to be addressed. Also, there should be 2 tranny filters..one in the tranny itself..and one in line from tranny to cooler in radiator. It goes without saying your about to know more about Subie's...good luck.
#5
Posted 28 March 2005 - 06:52 AM
1234,
Holy cow. there's another tranny filter??? Because if the other one was clogged to the point that the car wasn't driveable... I have the haynes for it and I don't think I saw any mention of the other filter. I'll have to look at the throttle cable what with the cold weather. I've fixed the check engine light, it was the coolant temp sensor. I tried a computer scanner from schucks and it wouldn't give me info on the O2 sensor.
I know that the square nut is for changing shift behavior-that's why I mentioned it. I asked a few people at schucks and they said it'd be one thing to consider.
Isn't the TPS just a simple mechanical variable switch? I'll look at it but I doubt it's bad, I know on my nissan the adjustment can be off and it's easy to fix, but the unit doesn't ever fail.
#6
Posted 30 March 2005 - 01:51 PM
#7
Posted 31 March 2005 - 02:37 AM
