Guest jcdenton Posted August 4, 2003 Share Posted August 4, 2003 Hello, what is this twin carb setup and how can I put it on my ea81 or, would a webber be better? I know that this is a general question, but some info would be great. Quote Link to comment Share on other sites More sharing options...
Guest GeneralDisorder Posted August 4, 2003 Share Posted August 4, 2003 IF you can find one, and the manifold, and the air filter housing - you can bolt it right up. They were common in Japan, and have arived here in the states on Japanese import motors. A weber would probably be better. Easier to tune, and easier to rebuild if the need arrises later. Do you really want twice the Hicrappy? :rollin: GD Quote Link to comment Share on other sites More sharing options...
Guest subarugsr Posted August 4, 2003 Share Posted August 4, 2003 does anyone know if twin weber carbs to fit an EA63 are still quite easy to find? Quote Link to comment Share on other sites More sharing options...
Guest GeneralDisorder Posted August 4, 2003 Share Posted August 4, 2003 Twin carter / webers? The only twin I know of is the twin Hitachi from the EA71 and EA81 - was there such a thing as twin carter / webers? I've heard of a carter / weber single barrel carb.... but I thought it was only a single carb. GD Quote Link to comment Share on other sites More sharing options...
Guest Caboobaroo Posted August 4, 2003 Share Posted August 4, 2003 I know Andrew has a twin carb setup which I believe is for an EA81...but not sure. You might wanna talk to him about it but I don't think he'll let it go. If he did, I'm thinking about stealing it for my EA71:lol: Quote Link to comment Share on other sites More sharing options...
Guest Flowmastered87GL Posted August 4, 2003 Share Posted August 4, 2003 They are for an EA71, I belive the air cleaner is missing for it, I'm sure you could fab one up pretty simply. Quote Link to comment Share on other sites More sharing options...
Guest Hondasucks Posted August 4, 2003 Share Posted August 4, 2003 That dual carb setup is >>>MINE<<< and it is for an EA71. Quote Link to comment Share on other sites More sharing options...
Guest Caboobaroo Posted August 4, 2003 Share Posted August 4, 2003 well I dunno cause I'm a little drunk so hey, give me some credit fro trying at least:p Quote Link to comment Share on other sites More sharing options...
Guest thesubarukid Posted August 4, 2003 Share Posted August 4, 2003 arent there a lot of these down in the outback (Aus.)? I seem to remember seeing that somewhere on here... Quote Link to comment Share on other sites More sharing options...
Guest SubieSTORMTROOPER Posted August 4, 2003 Share Posted August 4, 2003 Some have used a Carter 2 barrel from a 318 V8, which is just right. Of course these are used on the EA81's in airplanes, so you might want to do some work on the heads and cam to make it actually worth it. Quote Link to comment Share on other sites More sharing options...
Guest jcdenton Posted August 4, 2003 Share Posted August 4, 2003 I was going to go with a 32/36 webber anyway, but I just wanted to know about them. thank you. Quote Link to comment Share on other sites More sharing options...
