Welcome to Ultimate Subaru Message Board, an unparalleled Subaru community full of the greatest Subaru gurus and modders on the planet! We offer technical information and discussion about all things Subaru, the best and most popular all wheel drive vehicles ever created. We offer all this information for free to everyone, even lurkers like you! All we ask in return is that you sign up and give back some of what you get out - without our awesome registered users none of this would be possible! Plus, you get way more great stuff as a member! Lurk to lose, participate to WIN*!
* The joy of participation and being generally awesome constitutes winning ** Not an actual guarantee, but seriously, you probably won't regret it! Serving the Subaru Community since May 18th, 1998! |
Ebay Coilover Users, more info please...
#1
Posted 28 March 2005 - 01:58 PM
1. what struts are you using front and rear?
2. what is the "free length" of said springs?
3. what is your total range of height adjustment?
4. are all of you using WRX spec kits off ebay?
many thanks in advance for your info and experience.
garner
#2
Posted 28 March 2005 - 03:08 PM
adjustment range is around 3"
struts:
front-New O.E. xt6 2wd
back-KYB gr2 4wd sedan struts (i had original thought they were 2wd:rolleyes: )
wagon has HP coilovers for a vr6 VW
coupe is gettting Bomz coilovers for a integra
if your going to be using ea82 struts in the rear garner check here
http://www.ground-co...egory.php/CA=31 ..
there are a ton of different length and weight combintations for 2.5" diameter springs, which will fit..
#3
Posted 28 March 2005 - 03:24 PM
Seems to me the springs are about 6" tall... The collar adjustment is about 3".
#4
Posted 28 March 2005 - 03:48 PM
4WD EA82 struts in the rear
Spring were listed as being for an 02-04 WRX
4 inches of adjustment
350 pounds rear
450 pounds front
IIRC, they were 8 inches long without the collars.
#5
Posted 28 March 2005 - 04:11 PM
So with 4 inches of adjustment, I can go from "slammed" to mild lift with 4 inches of adjustment. My goal is to have the Brat play "Transformer" and go from slammed street rig to gravel road bomber with the twist of a wrench or two and swapping wheels and tires.... we'll see....
for struts, atleast for the rear, I'm going with 4wd wagon rears. According to my FSM, they are nearly the shortest but have the longest travel. I'm doing custom top mounts for the tops so I can set my starting height where ever I want....
on the ebay coilovers, those springs are 2.5" correct? so one could swap them out with ground control springs or the equivelent....
Tex, are your ebay coilovers wrx spec?
garner
#6
Posted 28 March 2005 - 11:43 PM
cool,
garner
IIRC, he used springs marketed for a legacy.
#7
Posted 29 March 2005 - 03:32 PM
these
http://cgi.ebay.com/...&category=33582
and these
the second look just like what calebz has, the first looks, well wierd.
What I don't understand about the first is what keeps the tupe from spinning when you turn the perch? Anyone have any wisdom on this?
garner
#8
Posted 29 March 2005 - 05:23 PM
Either of these setups use the same method to secure the threaded collar to the strut. Space is taken up between the collar and the strut by using rubber o-rings. This should be pretty tight. Then, at the bottom there will be 3 threaded holes to put in little threaded plugs. (in the second link, look to the bottom right of the picture) these clamp the collar to the strut... much like a xmas tree stand clamps in a tree.
I spose the sprigns could be 8" instead of 6"... I dunno.
These are all ripoffs of the Ground Control coilovers, which for what they are are over priced. Those do feature steel threaded collars instead of aluminium. You could put the ground control springs on these setups (the springs are eibach's) but I wouldn't. At that point I would rather upgrade to steel hardware... as I don't trust the aluminium that much.
#9
Posted 29 March 2005 - 06:13 PM
I'm running 250's and 200's in my rally car and i wouldn't drive anything stiffer on the street.
All the ebay type coilover kits are stupid stiff, and i don't believe that an 8 inch coil has enough travel built into it so accomidate the shock travel. You might end up coil binding your spring with only 4 inches of travel!!!!!! That's NOT good.
If it was me, and wanted to put together a coil over kit. Look into stock car places, which sell dirt track parts. They will list "coil over sleeves", you call them up with the OD of your struts, and they will match with whatever possible...you want the sleeves to slip over the struts tightly. The cheap ebay kits use o-rings to take up the slack!..not what you want to do.
The stock car placed can then provide you with whatever springs you want....with your desired spring rates.
if you go too stiff on the rate you will look like some punk in a civic that bounces down the road like a ballon!
with FRESH GR2 struts allround, i might go for a 175 or maybe a 200 in the front for a spring, then have the rears about 50 lbs lower.
The stock spring rates are ike 110-115ish...i think
The stock car place will end up being a little bit more..i think the sleeve kits are around 40 bucks CDN a corner, and the springs are around 60 a piece cdn.
better springs though.. that won't break
#10
Posted 31 March 2005 - 01:42 PM
yes, they are stupid stiff springs for sure. My plan is to use these as a mock up sort of thing. Once, I can determine exactly what I want in terms of length and rate, I'll order eibach springs from ground control. One of my main motivations in using this type of set up is dialing in the ride height. And compared to blown struts and tired springs, anything would be an improvement.....
good tip on the circle track coilover set up, I'll do some research on that as well.
The ebay coilover set up deal is kind of cheesey but it's cheap and according to the folks running them, they work ok.
garner
#11
Posted 03 April 2005 - 11:54 AM
I just limped my car all the way home from death valley with a blown out strut with a spring pearch that also blew off the strut housing. This was with a cheapy coil over set up like the ones you are looking at installed.
to be honest it never really did ride well. spring was too short and did not alow the suspension to fully travle its range smoothly.
this was notr too much of a problem on the street but flying down a dirt highway at 50 + mph was just too much for it. I crossed a washout a little too fast and it completely destroyed the right rear strut.
we found some old car parts out in the desert and were able to fashon a cheesey repair out of a cracked turbo housing that got us home but it was a slow and bouncy ride to be sure.
I am going to try and find true threaded body coil overs that I can adapt to the rear of the car. Im not messing with those adaptor sleves any more.
#12
Posted 20 May 2005 - 12:35 AM
Talking to the roundy round guys will (at least in my case) not get you very far unless you lie about what kind of car you're trying to work over. I couldn't get Afco or QA1 to even consider making a strut based on their rustang struts. They don't seem to see the market for US made Import parts....[roll].
If you do all of your own research and choose what springs and sleeves you want, you can end up with a decent setup on a budget but you have to match the struts with what springs you're trying to use. All of this has to match with what you want to do with the car.
Just 4" of travel not enough and too stiff? Try a set of tender springs.....or change the springs out for a set of 10-12" drag springs. The sleeves work fine despite the setscrew/O-ring method of attatchment. Careful wrapping of ductape around the struts(&under the sleeves)makes for solid mounting of the sleeves and the setscrews will lock it into place. I don't like the single alu. adjuster ring....I prefer the double locking rings even though I have to use tools to set them. I don't move them very often once they're where I want them.
#13
Posted 20 May 2005 - 12:35 PM
The GR2 is a good quality strut/shock/coilover(name changes depending on who you ask) but the dampening is too soft for any use that is harsher than regular street driving.
I still am not pleased with the coil over sleeve kit deals. I guess if all you really care about is ride height then thats fine.
if you want durability and performance then they are a poor choice in my opinion.
so what is the solution?
well I have somthing a little better in the rear right now but its still not perfect.
I found a set of dampening adjustable, fully threaded coil overs on E Bay. they fit some early gen mitsu. EVO. combined with a stiffer spring set I had here at home.(styles I still have parts for you)
I hade to make a few mods to fit them properly but they are in and have been tested now.
handling is great on the street. no real complaints there(except speed bumps).
in the dirt they really help me piviot around corners better as the understeer is almost completely gone.
the problem is still lack of travle. I watched the vidio of the car from the last RallyX I ran and in the chunky stuff the rear cannot soake up the bumps well.
so still waiting for the ultimate suspension on a budget to come along but progress has been made.
#14
Posted 20 May 2005 - 06:05 PM
Personally. i researched and found a proper custom made bilstien set-up for my rally car.. however it cost close to 1500 USD.
#15
Posted 20 May 2005 - 06:18 PM
ouch. no offense, but that's not exactly "within budget" for most people around here... I've got 3 xt6's that I didn't pay that much $$$$ for
#16
Posted 20 May 2005 - 10:33 PM
i just recommended the stock car stuff as an alternative to the ebay specials. They are made from better material, and you can use a spring rate better suited to your car.
If I had the cash for them and could verify that it would work how I want it to I would be all over that deal.
