98legacywv Posted March 30, 2005 Share Posted March 30, 2005 ok.. IM having oil leak issues... its coming from the back of the motor somewhere its not really bad but..... i checked the engine and got an incorrect oil measurement.. i put a quart in.. is a quart over enough to cause damage.. and the leak? Quote Link to comment Share on other sites More sharing options...
SevenSisters Posted March 31, 2005 Share Posted March 31, 2005 For about $7.50 you can drain and replace with the proper amount and not worry. Or, suck some out the dip stick tube. Sorry, I don't know if 1qt XS will hurt. Quote Link to comment Share on other sites More sharing options...
Tiny Clark Posted March 31, 2005 Share Posted March 31, 2005 And take some lightweight sandpaper to your dipstick, it makes it easier to read. Quote Link to comment Share on other sites More sharing options...
Spazz698 Posted March 31, 2005 Share Posted March 31, 2005 Too much oil in your motor can cause seals/gaskets to go once you hit the gas hard enough. I dont know how much oil you need to put in in order to accomplish this tho, the one time I tried (I was mad at a mustang I had) I kept popping the half assed "seal" around the dipstick tube since the sleeve has snapped and it was only held in place by the dipstick. Quote Link to comment Share on other sites More sharing options...
charlierh2 Posted March 31, 2005 Share Posted March 31, 2005 if your oil is over filled it can also get frothy and not cool properly... but i doubt 1 qt would do to much damage Quote Link to comment Share on other sites More sharing options...
subie94 Posted March 31, 2005 Share Posted March 31, 2005 ok.. IM having oil leak issues... its coming from the back of the motor somewhere its not really bad but..... i checked the engine and got an incorrect oil measurement.. i put a quart in.. is a quart over enough to cause damage.. and the leak? you said it's leaking at the back of the engine,can you see it like from the pan? on some 2.2 engines and maybe some 2.5s theres a plate that's behind the clutch in between the engine an trans that had a tendincy to leak cause it was made out of plastic.they will leak down through the seam of engine an trans an then of course on your driveway:rolleyes: hope this helped.of course i could be wrong to:banghead: Quote Link to comment Share on other sites More sharing options...
98legacywv Posted April 1, 2005 Author Share Posted April 1, 2005 you said it's leaking at the back of the engine,can you see it like from the pan? on some 2.2 engines and maybe some 2.5s theres a plate that's behind the clutch in between the engine an trans that had a tendincy to leak cause it was made out of plastic.they will leak down through the seam of engine an trans an then of course on your driveway:rolleyes: hope this helped.of course i could be wrong to:banghead: it only leaks when you drive it and it doesnt burn much.. just enough to make it smell.... Quote Link to comment Share on other sites More sharing options...
