vlipps Posted March 31, 2005 Share Posted March 31, 2005 I hooked up a trailer that wasn't properly grounded to my 2003 Baja and now the taillights and parking lights are always on unless I pull the #5 10a fuse. I've disconnected the small trailer lighting box near the hitch and it didn't help. I've been told to check the relays in the main fuse box but they are not labeled so that I can tell which one might be right. Since the relays seem difficult to remove, I'm hesitant to do more without further guidance. Any suggstions? Quote Link to comment Share on other sites More sharing options...
mattocs Posted March 31, 2005 Share Posted March 31, 2005 I hooked up a trailer that wasn't properly grounded to my 2003 Baja and now the taillights and parking lights are always on unless I pull the #5 10a fuse. I've disconnected the small trailer lighting box near the hitch and it didn't help. I've been told to check the relays in the main fuse box but they are not labeled so that I can tell which one might be right. Since the relays seem difficult to remove, I'm hesitant to do more without further guidance. Any suggstions? Did you happen to bump the switch on top of the steering wheel? (That wouldn't turn on the tail lights...would it?) Keep your headlights on all the time...they go out when the cars off. Quote Link to comment Share on other sites More sharing options...
mtsmiths Posted March 31, 2005 Share Posted March 31, 2005 Did you happen to bump the switch on top of the steering wheel? (That wouldn't turn on the tail lights...would it?) Keep your headlights on all the time...they go out when the cars off. The steering column rocker switch turns on front and rear parking lights. I second, another Subaru virgin bites the dust. There, see how easy a fix that was? Quote Link to comment Share on other sites More sharing options...
SevenSisters Posted April 1, 2005 Share Posted April 1, 2005 Don’t be embarrassed. Did that work? I went through fits when it happened to me. My wife pointed out the switch after reading the manual. I don’t need no stinking manual! Quote Link to comment Share on other sites More sharing options...
georgeinmd Posted April 1, 2005 Share Posted April 1, 2005 "Bajas? We ain' got no Bajas. We don' need no Bajas. I don' have to show you any steengkeeng Bajas!"...? (JUST KIDDING!!!!!) Quote Link to comment Share on other sites More sharing options...
vlipps Posted April 3, 2005 Author Share Posted April 3, 2005 I do keep the headlights on all the time and they do go off when I turn the car off. However, now my tailights and parklights stay on even when everything is off until I pull the #5 10a fuse. Did you happen to bump the switch on top of the steering wheel? (That wouldn't turn on the tail lights...would it?) Keep your headlights on all the time...they go out when the cars off. Quote Link to comment Share on other sites More sharing options...
mattocs Posted April 3, 2005 Share Posted April 3, 2005 I do keep the headlights on all the time and they do go off when I turn the car off. However, now my tailights and parklights stay on even when everything is off until I pull the #5 10a fuse. Even when the car is all the way off the taillights and parking lights are still on? Quote Link to comment Share on other sites More sharing options...
vlipps Posted April 3, 2005 Author Share Posted April 3, 2005 I just went out and checked and sure enough, that switch was on & keeping my taillights on even when the ignition was off. How simple! Thnaks! Did you happen to bump the switch on top of the steering wheel? (That wouldn't turn on the tail lights...would it?) Keep your headlights on all the time...they go out when the cars off. Quote Link to comment Share on other sites More sharing options...
mattocs Posted April 3, 2005 Share Posted April 3, 2005 I just went out and checked and sure enough, that switch was on & keeping my taillights on even when the ignition was off. How simple! Thnaks! So it was the switch on the top of the steering wheel? It happens to a lot of people...all the time. Quote Link to comment Share on other sites More sharing options...
