hschwab Posted April 7, 2005 Share Posted April 7, 2005 i purchased a 1998 radio/cass/cd off ebay. the cd player has a two wire connector with a red wire and a red/green wire. is the red wire for illumination and the red/green wire for 12+ constant. can i tap into andy red, red/green wire to get the power i need? need any help i can get. Quote Link to comment Share on other sites More sharing options...
Chef Posted April 8, 2005 Share Posted April 8, 2005 I wouldn't try tapping into any, but there's an easy way to check. Use a voltmeter to see if both run 12+ volts while in the ON position. Then, turn the ignition to ACC or lock and see which one still has 12 V. That's the constant. I just wired up a CD player for my 92 legacy, and had a heck of a time. Always used an adapter before - apparently no one makes an adapter for subes. I think in my case it was a red/yellow that was my power, and a red/blue my constant. Or was that the other way around? i purchased a 1998 radio/cass/cd off ebay. the cd player has a two wire connector with a red wire and a red/green wire. is the red wire for illumination and the red/green wire for 12+ constant. can i tap into andy red, red/green wire to get the power i need? need any help i can get. Quote Link to comment Share on other sites More sharing options...
Tiny Clark Posted April 8, 2005 Share Posted April 8, 2005 If you don't have a voltmeter, invest in a test light. They have a sharp point on them, so you can pierce the wire and easily check for the presence of 12 volts with the key on and off. Quote Link to comment Share on other sites More sharing options...
