WRX exhaust on legacy SS?
4 replies to this topic
#1 kidwired
    USMB Regular
  • PipPipPip
  • 72 posts
  • Sonoma
Posted 08 April 2005 - 10:17 AM
I've been reading on this a bit but still dont understand everything that would be needed.
I found an ad for WRX factory exhaust "fits 02/03 wrx.. full exhaust system including up-pipe to muffler.. very good shape, price is firm.. "
Does that sound like everything I need? except the muffler I guess?
#2 calebz
    Andys Coupe killed my cat
  • Administrator
  • 7,547 posts
  • Tacoma
Posted 08 April 2005 - 10:56 AM
The downpipe shold fit. As well as the second DP piece and the mid pipe (although the mid pipe may require a custom hanger.
Not sure if the tailpipe /muffler piece will fit or not.
The uppipe won't fit as far as I know. Main reason being that the flange that the turbo mounts on is different. Now if you were to change from the VF11 to a TD04, you may have better luck there, but I don't know if the EJ22 uppipe is more like the EJ20 or if its integrated like the EA82
#3 kidwired
    USMB Regular
  • PipPipPip
  • 72 posts
  • Sonoma
Posted 08 April 2005 - 11:32 AM
I am considering a tdo4 swap, wondering if this wouldnt make it easier.
I understand the wrx up-pipe has a 3rd cat in it :(
I dunno I guess my pipes are 2" and the wrx is 2.25", seems like alot of work for not much gain. A custom 3" is sounding a better option.
#4 offroadsubaruguy
    Subaru Nut
  • 729 posts
  • arvada, colorado
Posted 15 April 2005 - 12:36 PM
you will have to lenghten the mid pipe section by at least 6 inches or so.... im not sure if the down pipe sticks farther out than the stock y pipe does on the na cars...... i tried to fit one and the flanges are different, and the mid section is seriously short........ but should be easy to lengthen..... just my .02
#5 kidwired
    USMB Regular
  • PipPipPip
  • 72 posts
  • Sonoma
Posted 15 April 2005 - 08:58 PM
heres what I have found out, turbo legacy and wrx exhaust are the same diameter etc. Even the left side manifold is the same part #. We both have cats in DP, the WRX however has a cat in the header. No real performance to be gained.....anywhere. Well except that now I will replace my 12 yr old exhaust w/ a 2mo old exhaust, not bad.
I am going to cut the cats out of the wrx system and install it. Then I will put the nice new cats in my old midpipe so I can swap it in for smog testing.
Caleb, you just answered my question.
