kidwired Posted April 8, 2005 Share Posted April 8, 2005 I've been reading on this a bit but still dont understand everything that would be needed. I found an ad for WRX factory exhaust "fits 02/03 wrx.. full exhaust system including up-pipe to muffler.. very good shape, price is firm.. " $100 Does that sound like everything I need? except the muffler I guess? Chris Quote Link to comment Share on other sites More sharing options...
calebz Posted April 8, 2005 Share Posted April 8, 2005 The downpipe shold fit. As well as the second DP piece and the mid pipe (although the mid pipe may require a custom hanger. Not sure if the tailpipe /muffler piece will fit or not. The uppipe won't fit as far as I know. Main reason being that the flange that the turbo mounts on is different. Now if you were to change from the VF11 to a TD04, you may have better luck there, but I don't know if the EJ22 uppipe is more like the EJ20 or if its integrated like the EA82 Quote Link to comment Share on other sites More sharing options...
kidwired Posted April 8, 2005 Author Share Posted April 8, 2005 I am considering a tdo4 swap, wondering if this wouldnt make it easier. I understand the wrx up-pipe has a 3rd cat in it I dunno I guess my pipes are 2" and the wrx is 2.25", seems like alot of work for not much gain. A custom 3" is sounding a better option. Quote Link to comment Share on other sites More sharing options...
offroadsubaruguy Posted April 15, 2005 Share Posted April 15, 2005 you will have to lenghten the mid pipe section by at least 6 inches or so.... im not sure if the down pipe sticks farther out than the stock y pipe does on the na cars...... i tried to fit one and the flanges are different, and the mid section is seriously short........ but should be easy to lengthen..... just my .02 Quote Link to comment Share on other sites More sharing options...
kidwired Posted April 16, 2005 Author Share Posted April 16, 2005 heres what I have found out, turbo legacy and wrx exhaust are the same diameter etc. Even the left side manifold is the same part #. We both have cats in DP, the WRX however has a cat in the header. No real performance to be gained.....anywhere. Well except that now I will replace my 12 yr old exhaust w/ a 2mo old exhaust, not bad. I am going to cut the cats out of the wrx system and install it. Then I will put the nice new cats in my old midpipe so I can swap it in for smog testing. Caleb, you just answered my question. Quote Link to comment Share on other sites More sharing options...
