zyewdall Posted October 3, 2005 Share Posted October 3, 2005 Arn't the vanagon diesel engines inline, aka the same as the jetta, golf...... Matt Yup, they're just tilted over on their side about 35 degrees to fit in the vanagon engine bay. Quote Link to comment Share on other sites More sharing options...
soobme Posted October 3, 2005 Share Posted October 3, 2005 Right Matt, inline. But I think that IF U are going to put a D. into a roo, the VW IS the way to go. I would use the oil pan, pick-up, ect. from the Vanagon and mount it the same way. Would give ALOT more clearance under the EA81 & EA82 hoods. Quote Link to comment Share on other sites More sharing options...
Petersubaru Posted October 3, 2005 Share Posted October 3, 2005 do you mean to add a turbo to a N/A motor So turbo it! :cool: Quote Link to comment Share on other sites More sharing options...
zyewdall Posted October 3, 2005 Share Posted October 3, 2005 do you mean to add a turbo to a N/A motor You could, but the diesel guys recommend against running too much boost if you do that, and to especially watch the EGT's. The turbo motors have oil cooled pistons which the NA ones didn't. You can apparently melt the pistons.... Quote Link to comment Share on other sites More sharing options...
zyewdall Posted October 3, 2005 Share Posted October 3, 2005 Right Matt, inline. But I think that IF U are going to put a D. into a roo, the VW IS the way to go. I would use the oil pan, pick-up, ect. from the Vanagon and mount it the same way. Would give ALOT more clearance under the EA81 & EA82 hoods. I agree, and that's most likely what I'm planning on doing. But Kubota also makes some pretty nice turbo diesel engines, and the bigger ones are around 1.7 - 1.9 liter. Three cylinder so they might fit better in the length department, but I don't know about height. They usually redline at 3,600 though, so you'd have gobs of low end torque, but nothing on the highway.... Quote Link to comment Share on other sites More sharing options...
Snowman Posted October 3, 2005 Share Posted October 3, 2005 do you mean to add a turbo to a N/A motor Yeah. Put a turbo on it from an EA82T or something. I think there's an adjustment for max fueling on the VW pumps, which you could probably turn up a bit. I'm not sure if the timing would need tweaking. Just get an EGT gauge and watch it religiously while you experiment. Quote Link to comment Share on other sites More sharing options...
soobme Posted October 3, 2005 Share Posted October 3, 2005 I agree, and that's most likely what I'm planning on doing. But Kubota also makes some pretty nice turbo diesel engines, and the bigger ones are around 1.7 - 1.9 liter. Three cylinder so they might fit better in the length department, but I don't know about height. They usually redline at 3,600 though, so you'd have gobs of low end torque, but nothing on the highway.... Might RL@3600RPM, but I bet they make GOOD power all the way there. With a 5spd, and 3.70's insted of 3.90's it should work great. But I'm not sure if U can get 3.70 gears in a 5spd Man. trans. Running big tires would help too. 27's @ least, 28's or 30's would work even better. U would still have all the TQ U need on the bottoum Quote Link to comment Share on other sites More sharing options...
Petersubaru Posted October 10, 2005 Share Posted October 10, 2005 it is more then just adding a turbo and ajusting the fuel ratio..turbos that come from the factory also have injection pumps that put out more pressure along with different injectors Yeah. Put a turbo on it from an EA82T or something. I think there's an adjustment for max fueling on the VW pumps, which you could probably turn up a bit. I'm not sure if the timing would need tweaking. Just get an EGT gauge and watch it religiously while you experiment. Quote Link to comment Share on other sites More sharing options...
