Welcome to Ultimate Subaru Message Board, an unparalleled Subaru community full of the greatest Subaru gurus and modders on the planet! We offer technical information and discussion about all things Subaru, the best and most popular all wheel drive vehicles ever created. We offer all this information for free to everyone, even lurkers like you! All we ask in return is that you sign up and give back some of what you get out - without our awesome registered users none of this would be possible! Plus, you get way more great stuff as a member! Lurk to lose, participate to WIN*!
* The joy of participation and being generally awesome constitutes winning ** Not an actual guarantee, but seriously, you probably won't regret it! Serving the Subaru Community since May 18th, 1998! |
1990 Legacy Auto transmission problem
#1
Posted 03 September 2003 - 09:53 AM
#2
Posted 03 September 2003 - 10:05 PM
ScoobySchmitty
#3
Posted 04 September 2003 - 08:53 AM
#4
Posted 04 September 2003 - 01:15 PM
Well, now that you own a Legacy autotrans, that'll surely change! Not to dog on Subaru but I haven't been too impressed with their autotransmissions. It doesn't seem like too many people know how to work on them, even Subaru service! Seems like the number one solution is "REPLACE IT!$$$!" Good luck!
#5
Posted 10 November 2005 - 08:23 PM
My philosophy is I will either break it, fix it or part it out. Wish I could add to any hope for the fix but just telling you my end here. Going to dump mine and go back to old subbies and trucks. Mines for sale now but good luck and hope you find the silver bullet. Lots of good ideas come on this site. Mike
#6
Posted 10 November 2005 - 08:45 PM
#8
Posted 10 November 2005 - 10:22 PM
did you properly seat the input shaft of the torque converter when installing the torque converter? it typically takes awhile and is a little frustrating/time consuming to get it to seat the last 1/4 inch. if you don't seat it that final 1/4 inch it will ride on top of the oil pump rotor and not actually seat in it, then when you bolt things up tyipcally the oil pump rotor breaks. maybe yours somehow made it past the first start up? never heard of that happening before, but the biggest mistake made with auto trans installs of the 4EAT's is not seating that last 1/4 inch properly. has to be lined up just right to slide the last 1/4 inch. if you had trouble getting the trans bellhousing and engine to meet flush without torquing the bolts down then this is probably your problem.
#9
Posted 13 February 2006 - 08:35 PM
My son was driving it and said he heard/felt a pop and then it would not do anything in forward or reverse. I was always suspect of the transmission so I decided to just replace it. I found a person parting out her subby sedan (93 I think) with 104k mi. and purchased the tranny for an awesome price of $130. I remove the old trans and installed the used one I had purchased. After putting new ATF and gear oil in to the proper levels, replacing engine oil and filter, and installing new spark plug wires (someone took one of the wires) I fired up the engine and warmed it up. I back out of the driveway and drove it about 1/2 mi down the road, turned around and head back home. About half way back I felt a pop and then nothing...no forward or reverse..same as with the tranny I just replaced. I pushed it back home and parked it.
Any ideas on the problem? It is too much of a coincidence to have 2 trannys do the same thing.
#10
Posted 13 February 2006 - 09:00 PM
#11
Posted 13 February 2006 - 09:18 PM
#12
Posted 13 February 2006 - 09:40 PM
How are your CV joints? The trouble must be outside of your tranny(?). The auto should move with a broken drive shaft but the manuals don't. Anybody know if the autos will move with a broken CV?Awd
#13
Posted 13 February 2006 - 11:13 PM
#14
Posted 14 February 2006 - 12:05 AM
As far as the CV's go, I'm pretty sure they are fine. I'm familiar with CV's going bad, although I've only had problems with CV's in the front...
Blackbart; remember, after replacing the tranny, the car went approx 3/4 mi before it quit again. If it was a broken CV that was the original problem, it wouldn't of moved after replacing the trans.
#15
Posted 14 February 2006 - 12:48 AM
#16
Posted 14 February 2006 - 01:50 AM
#17
Posted 14 February 2006 - 02:55 AM
Tap into your tranny cooler line (with a "T") and check for pressure with a gauge, or hook up to pump pressure port on side of pump housing (between diff and AT cases). Might want to check a book for which of the three or four screws is the one you need. if no pressure from either one...bad pump, or something before it, Torque conv. shaft, flex plate, ect.
I can try the tranny cooler line as those lines are easy to access..but (now I don't know much about auto trannys) doesn't the tranny have a gear style pump INSIDE the tranny and if so...how could the pump be bad on both trannys?
Also, remember, two trannys went bad back to back, the 2nd one after only about 3/4 mi after install...
#18
Posted 14 February 2006 - 10:42 AM
#19
Posted 14 February 2006 - 10:57 AM
#20
Posted 14 February 2006 - 11:09 AM
Did you use the same torque converter?
I appreciate the replies! I agree about the potential outside cause. My first reaction to the pinched cooler lines would be that it is not the problem. There has been no recent damage to the vehicle and during the tranny swap I did not see any damage to the lines. I will have to look at them closer where they go into the radiator.
Yes, I used the same torque converter..:-\
#21
Posted 14 February 2006 - 11:21 AM
I would lean toward trying a rebuilt torque converter. My automatic tranny place has a dyno where you can test it out of the car. anything like that near you?
#22
Posted 14 February 2006 - 06:06 PM
the torque converter has a couple of seals that must hold pressure on most vehicles I have worked on. I've never had a Subaru automatic so most of these folks know more about them than I do. I think the closest thing to this would be a Toyota forklift for me.
I just spoke to my subaru mechanic (independant) and he hasn't heard of anything like this before either. His first suggestion was same as several of you have suggested, check to see if the pump is working via a gauge in one of the test holes. He also mentioned to pull one of the cooling hoses and see if the pump is pumping ANY fluid at all. One other item he mentioned is a tube that goes from the torque converter through the axle housing to the tranny. If the tube didn't get in the right place or was damaged during the R & R of the trannys then no pressure would be going between the TC and the tranny....
#23
Posted 14 February 2006 - 06:17 PM
#24
Posted 02 May 2006 - 02:11 PM
Oh man..I found this forum in an effort to try and figure out what the problem is with my 90 legacy awd wagon with auto tranny. Reading this post sounds real similar to my problem.
#25
Posted 02 May 2006 - 03:23 PM
