00 RS springs/struts fit 93 SS?
6 replies to this topic
#1 kidwired
kidwired
    USMB Regular
  • PipPipPip
  • 72 posts
  • Sonoma
Posted 11 April 2005 - 02:50 AM
Edit:OMG, I shouldnt post when I'm so tired. Just got back from Tahoe and found an ad for RS suspension stuff for $50. I got so excited had to post.
Guess I'll search now.
I'll try and remain calm and coherent but I can't make any promises.
#2 GLCraig
GLCraig
    Livin' the live
  • 2,706 posts
  • LV, Washington
Posted 13 April 2005 - 08:29 PM
nope, 2000 the rear suspension was changed.
#3 kidwired
kidwired
    USMB Regular
  • PipPipPip
  • 72 posts
  • Sonoma
Posted 13 April 2005 - 11:55 PM
ok heres how I understand it. Yes the suspensions are interchangeable. for rears you have to use 92-94 top hats. my car is 93 so no prob.
Heres why I am not doing it, Spring Rates. WRX fronts are only moderately stiffer than SS, WRX rears have LESS spring rate (WRX is a lighter rear). The RS springs have less rate than the WRX so the point is rather moot.
#4 TheSubaruJunkie
TheSubaruJunkie
    Subaru Sober since 2010 :(
  • 1,907 posts
  • Sacramento
Posted 14 April 2005 - 12:53 AM
I was going to do this when i had my 92 SS, but never got around to it. Some told me it was a direct bolt on.
-Brian
#5 Qman
Qman
    Happiness is... no lag!!
  • Moderator
  • 11,109 posts
  • Sumner
Posted 14 April 2005 - 11:08 AM
Tapered rear springs for the SS. This means the struts and front springs will fit. I have a complete ver5 STi suspension and white line springs along with camber plates for the front and STi top mounts for the rear. I haven't gotten to the point to verify that the rear springs will or won't fit.
#6 GLCraig
GLCraig
    Livin' the live
  • 2,706 posts
  • LV, Washington
Posted 14 April 2005 - 07:23 PM
maybe I'm thinking of a later year that they made some significant changes to the rear suspension.
#7 jamal
jamal
    1000+ Super USER!
  • 1,015 posts
  • Los Angeles
Posted 15 April 2005 - 12:35 AM
The whole assembly with strut tops and everything will bolt right in. I think scottzg on legacycentral has RS suspension on his Legacy.
By switching the rear strut tops with Group-N GC strut tops, I'm putting 2004 USDM STi suspension in my 93 Legacy.
93-01, Imprezas were pretty much the same as the BC/BF (and I think BD/BG). On Imprezas, after 01 the bolt pattern on the rear tops changed, so new strut tops are needed to fit 02+ suspension. For 05, the front hubs of the STi changed. Everything else is pretty much the same, and will fit a BC/BF. I think 95-99 Legacies are also the same. For 00 the rear changed and doesn't fit.
Some of us think that the strut tops are all the same pretty much until 02. 90-99 Legacy tops are the same as 93-01 Impreza tops. The upper spring perch changed.
http://bbs.legacycen...opic.php?t=2153
