I've recently acquired a '97 Subaru Impreza Outback and need to partially drain the coolant so I can replace the upper radiator hose without a big fluid mess.
Unfortunately, I have yet to order a service manual and at first quick glance was unable to locate a drain plug/valve.
I'd hate to remove the lower radiator hose just to partially drain the radiator. Is there a drain plug/valve for the '97 Impreza Outback radiator? Is it towards the bottom, on the left/right?
Yep, drain cock is on same side as the top rad hose, only right at the bottom. Often on the side of the rad.
Get under the car, remove the protective plastic shield and you will have good access.
Mount the new hose on the engine first and fill as far as possible through the top hose. Then connect it to the rad and top up from there. This method avoids large air pockets forming.
