porting for ze webber
4 replies to this topic
#1 JWX
JWX
    Lonely driver
  • 3,073 posts
  • Atlanta
Posted 13 April 2005 - 12:45 AM
so I have a spare intake manifold and I want to port out the flange some (just make it and the adapter bigger) what should I use?
#2 Ross
Ross
    Can't be bothered
  • 1,865 posts
  • Christchurch, New Zealand
Posted 13 April 2005 - 01:04 AM
Die grinder if you have one.
#3 JWX
JWX
    Lonely driver
  • 3,073 posts
  • Atlanta
Posted 13 April 2005 - 01:46 AM
I should have said that I was going to use a die grinder, but I wanted to know what stones/sanding drums to get.
#4 BobBrumby
BobBrumby
    Subaru Nut
  • 583 posts
  • Brisbane, Australia
Posted 13 April 2005 - 03:30 AM
Could you post some pics of the work when its done, cause I was thinking of doing the same thing when i was instaling my holley?
#5 TomRhere
TomRhere
    Certified BRAT nut!!!
  • 4,593 posts
  • Hillsdale, Mi. USA
Posted 13 April 2005 - 04:38 AM
I ported the (EA-82) manifold on mine when I installed the Weber, using a blunt tip rotary file mounted in an electric drill. I C-clamped the manifold to the work bench, mounted all of the spacers, adapters and what-nots using extra bolts. Then I just blended everything together to get rid of that stairstep look of the port opening. Got alittle close to the water port, but I filled it with some Liquid Aluminum, (kinda like JB Weld), after cleaning the area good, and smoothed it off level with the top of the manifold.
