'02 Forrester with CEL
13 replies to this topic
#1 ~Ron~
~Ron~
    New User
  • PipPip
  • 10 posts
Posted 18 April 2005 - 01:16 PM
I'm new to this board and have been doing various searches but haven't yet found what I'm after, perhaps someone could help?
I have an '02 Forrester with ~40K miles and the CEL light just came on. The local dealer wants almost $100 just to tell me what the problem is. Is there a way to find out at least what code is being sent that triggered the CEL?
I've tried the gas cap, and that didn't get the CEL to go away. I'm open to other suggestions also.
Thanks in advance for your help.
Ron
#2 Cougar
Cougar
    Elite Master of the Subaru
  • 6,563 posts
  • Anchorage
Posted 18 April 2005 - 02:02 PM
Welcome to the forum.
You can purchase a scanner from a parts store or go to a place like Autozone that will check them for free.
#3 ~Ron~
~Ron~
    New User
  • PipPip
  • 10 posts
Posted 18 April 2005 - 02:43 PM
Thanks!
#4 Brick
Brick
    New User
  • PipPip
  • 12 posts
  • Shoreview
Posted 19 April 2005 - 06:38 AM
www.scangauge.com
tool works pretty well, it's self contained and not terribly expensive.
#5 Johngenx
Johngenx
    USMB Regular
  • PipPipPip
  • 85 posts
  • St. Albert, Alberta
Posted 19 April 2005 - 08:04 AM
$100 just to read the code? Robbery! And the dealers wonder why we beat them up?
#6 novadog
novadog
    New User
  • Pip
  • 4 posts
Posted 19 April 2005 - 11:58 AM
Wouldn't this be covered by either the emissions or power train warranty?
#7 Brick
Brick
    New User
  • PipPip
  • 12 posts
  • Shoreview
Posted 19 April 2005 - 12:42 PM
Depends on what the fault code is. Might also be worthwhile to check w. Alldata to see if there are any known issues/recalls that might be related to the light (get the code first tho).
e.
#8 howards11
howards11
    2000 Forester L
  • 667 posts
  • PHL
Posted 19 April 2005 - 12:57 PM
www.scangauge.com
The web site states that it will NOT work on 1996-2000 Subarus.
~Howard
:confused:
#9 ~Ron~
~Ron~
    New User
  • PipPip
  • 10 posts
Posted 20 April 2005 - 05:33 AM
Thank you once again for the suggestions. At first I tried the gas cap and the CEL light came back on again and stayed on for a short trip (4 miles). But now it has gone off and stayed off for two fairly long (30+ miles) trips. I'm thinking it might have been a gas cap after all and the component driving the CEL needed more time to "recognize" that the cap had been tightened and then clear the code.
Is it ok to blame the gas cap episode on my wife... ;-)
#10 howards11
howards11
    2000 Forester L
  • 667 posts
  • PHL
Posted 20 April 2005 - 09:22 AM
I've had two episodes involving the gas cap. They take a LONG time to clear.
Both were my fault because the wife refuses to fill up the Forester. I put on a locking gas cap which my better half doesn't like to use.
~Howard
#11 Brick
Brick
    New User
  • PipPip
  • 12 posts
  • Shoreview
Posted 20 April 2005 - 02:57 PM
~Howard
:confused:
Since the vehicle in question is an '02, shouldn't be a big deal, but yeah, I agree, it seems a little goofy. For giggles I should try it on my 98 Legacy and see what happens.
#12 mtsmiths
mtsmiths
    Subaru Master
  • 1,660 posts
  • Kailua-Kona, Hawaii
Posted 20 April 2005 - 03:19 PM
I've had two episodes involving the gas cap. They take a LONG time to clear. :)
To clear the code battery dance it.
Roll down your window so you can reach into the ignition swaitch, and turn off all accessories. Disconnect the battery for at least 15 mins. (I do an hour). Reach in and start the car without opening any circuits. Allow the car to idle 15 mins, then shut it off. After that drive normally, the CEL should be gone.
#13 Johngenx
Johngenx
    USMB Regular
  • PipPipPip
  • 85 posts
Posted 20 April 2005 - 06:11 PM
On OBD-II cars (all 1996-) this is an unnecessary measure. The CEL will come back on if the condition is not fixed.
If the condition has been "repaired" then the CEL will go off after so many cycles and diagnostic checks. If you have fixed the problem with the gas cap, then the light will not return. If it comes back, and you can't get it to go away, read the codes and begin a diagnosis.
#14 ~Ron~
~Ron~
    New User
  • PipPip
  • 10 posts
Posted 23 April 2005 - 02:28 PM
e.
Thanks! I didn't know about Alldata, very cool. There is a recall listed but the dealer claims it doesn't apply to my car that they did the repair "at the port". Sounds like a line, he suggested I appeal to Subaru directly but that sounds like a waste of time.
