oil leak onto cat
6 replies to this topic
#1 hatchsub
    Currently Subaru-less :(
  • 2,714 posts
  • Guilford
Posted 20 April 2005 - 08:45 PM
Im new to the USMB but have an old school suby. Its an 83 with 54000 on the clock. My problem with it right now is that it leaks oil right onto the cat and its burning off in big clouds of blue when i stop. My shop said its the rear main seal. Does this require pulling the engine like i think it does. Could they have been mistaken and could it really be my oil pan. I had an 86 that leaked a lot from the pan so thats why im asking. Thanks for any help u can give.
#2 85Sub4WD
    EA82 Junkie
  • 1,244 posts
  • Raleigh NC/Charlotte NC
Posted 20 April 2005 - 08:51 PM
It could be the oil pan or a number of other places dripping and it getting blown onto the cat converter - best option is to thourghly clean the engine, and check for leaks again - you can pull the engine or transmission to do the rear main seal if that is the case - if it is the oil pan I would probably just take the engine mounts loose and raise it a bit.
#3 erik litchy
erik litchy
  • 1,090 posts
  • Peoria IL
Posted 20 April 2005 - 08:56 PM
mine was doing that too i think the rear main made that happen. its hard to say with my pos engine.
#4 All_talk
    1000+ Super USER!
  • 1,093 posts
  • Thorp (Ellensburg)
Posted 20 April 2005 - 11:18 PM
All Subie sooner or later get oil leaks and they always seem to end up on the exhaust, which leads to this bit of Subaru wisdom...
How do you know when your Subaru is out of oil... You can't smell it burnning off the exhaust any more. :-p
#5 Snowman
    Midnight Passenger
  • 3,538 posts
  • Haines
Posted 21 April 2005 - 12:44 AM
Either the rear main seal or pan gasket could leak onto the cat very easily. Pulling the engine is very easy on the older soobs like yours, so even if it's the rear main seal, you could do it in a day without much trouble.
With that little mileage on the car (54,000 miles?! Holy crap!!!:eek: ), I would guess it has sat for long periods of time, which can dry up the seals. I would not be at all surprised if the rear main is leaking. You should also look at the front crank seal as well as the oil pump and rocker cover gaskets. Oil can actually find its way back to the cat from those places as well.
#6 karinvail
    Eat, Live, Breath Subaru
  • 325 posts
  • Skagit County
Posted 21 April 2005 - 01:26 AM
when the CV boots tear on the front axles, they FLING that grease everywhere, and usually on the exhaust too. Putrid smell - I have always been able to tell the very day that I lose a CV boot, LOL.
#7 Bucky92
    Drive Fast, Take Chances
  • 3,664 posts
  • New Milford
Posted 21 April 2005 - 04:35 AM
Hey!! Another CT Subie owner...Yeah!:banana:.
My Bucky leaks oil from everywhere....I just call it "marking his territory".
If you want to...Sat and Sunday in Milford CT Moosens is having a get together. Lots of parts for just about everything up to 89 and Loyales. He is moving across town and needs to clean house.Come on down ..there will be much knowledge around (plus we can oogle over your low mileage car:grin: )
There really isnt anything hard to do on these cars if you have a place to do it and the right tools.
