86 gl-10 carrier bearing??
i have never serviced the carrier bearing, but i think its pressed in.
but the most economical solution is to go find another driveshaft if it can be had for cheap.
however you go, here is what to look for in driveshafts:
find out what trans you have. the auto tranny has the front half of the driveshaft shorter than the manuals
all auto drivehafts are the same length, whereas all manual driveshafts are the same length, respectively.
the rear half of either are the same length, but the carrier bearing is on the front half.
you actually need only the front half of the driveshaft for your transmission, the one with the bearing mounted to it.
i hope that answers ya, i couldnt tell you where to get a replacement, or how much it costs
