carfreak85 Posted September 5, 2003 Share Posted September 5, 2003 So guys, whats the deal with this swap? I've heard a lot of talk on this subject but no difinitive answers! (Maybe i just missed them though!) Heres what I've heard so far: 1. To fit it you must have a 6" lift 2. Requires cutting of chassis 3. It can be done with out cutting or lift. Who knows for sure? Quote Link to comment Share on other sites More sharing options...
ShawnW Posted September 5, 2003 Share Posted September 5, 2003 So it seems you can do it with less but I don't see how you would get it in without a lift kit. I think cutting the chassis is unnecessary the motor LENGTH is the problem not width. Its a TIGHT fit to the radiator. Quote Link to comment Share on other sites More sharing options...
carfreak85 Posted September 5, 2003 Author Share Posted September 5, 2003 You know im talking about an 84, right? I always thought that that since the EJ is OHC that it was too wide to fit snugly, but if its just the radiator, then there is really no issue. Quote Link to comment Share on other sites More sharing options...
Dr. RX Posted September 5, 2003 Share Posted September 5, 2003 Freak, most of the item you mentioned were reasons why not to install an EA82 into an EA81 series car, the EJ series engine is narrower then the EA82 so no cutting is necessary. But Like Shawn stated, the engine is a little longer. But bolting up the EJ into an EA81 series car is not the MAJOR problem, that is getting it wired correctly so that it will run. Also since it is a fuel injected engine, it will need a different, high pressure fuel pump. If you are really serious about doing this, let me know, I do have experience with this type of a conversion. Quote Link to comment Share on other sites More sharing options...
TomRhere Posted September 5, 2003 Share Posted September 5, 2003 I was told that I couldn't have the EA-82 engine in my '82 BRAT, cause it wouldn't fit between the frame rails, with-out a lift or cutting the rails. It does fit, tightly, but it fits. If the EJ engines are narrower side-to-side, you'll have enough room there. The engine in my BRAT originaly had the water pump mounted fan, and it sat about a 1/4" or less from the radiator. I promptly removed that. Not sure how much longer front-to-rear the EJ is from the EA-82, but I have 2-3/8" between the studs on the water pump and the radiator, a 2-core EA-82 type. So you may have to relocate the radiator. As far as the FI stuff, you could go with the CIS conversion like Noah did on his Wagon. Looks to be an easy conversion, for the do-it-myselfer. There's even one for the 5 cylinder engines, which has the fitting capped-off for the 6th cylinders injector. Just some more info here is all............. Quote Link to comment Share on other sites More sharing options...
Dr. RX Posted September 5, 2003 Share Posted September 5, 2003 In UltimateRX, there was no room for a fan larger the 2 inches thick, so I mounted some pusher fans were the A/C condensor used to be. On last check, UltimateRX was still not in top running shape, and too many other project, so it will wait awhile. The fans worked well enough for the times I had the engine running. Quote Link to comment Share on other sites More sharing options...
JWX Posted September 6, 2003 Share Posted September 6, 2003 could we get an update on the UltimateRX? Quote Link to comment Share on other sites More sharing options...
MilesFox Posted September 6, 2003 Share Posted September 6, 2003 Originally posted by TomRhere I was told that I couldn't have the EA-82 engine in my '82 BRAT, cause it wouldn't fit between the frame rails, with-out a lift or cutting the rails. ............ ....and ea82 front suspension was supposed to not fit on an 83 wagon. but somehow it does:dead: Quote Link to comment Share on other sites More sharing options...
