The Truth about RX Turbo Fuel Injector Flow Rates
38 replies to this topic
#26 oddcomp
oddcomp
    Subaru Master
  • 1,763 posts
  • longview ,wa
Posted 04 August 2005 - 04:09 PM
hmm maybe i will try myx's flowed injector rating on my rx's fuel table and see how well it likes it ..
i have mine set for 80 cc a min on my megasquirt setup and it seems to run pretty good for a tired old motor
edit: my one key is borked .. so make that one eighty cc's
#27 the_postie
the_postie
    USMB is life!
  • 145 posts
  • brisbane.aust
Posted 05 August 2005 - 06:17 AM
some guy in new zealand fitted 1983 jaguar xj6 injectors into his rx.they fit straight in with a change of o-ring.possum Borne used these in his rx rally car in the day.
#28 soobscript
soobscript
    needs more time
  • 705 posts
  • Columbus, OH
Posted 30 August 2005 - 03:45 PM
Just got mine back from RC. Injectors from an 88 RX. #1 and #3 might be switched, but #2 and #4 are the correct cylinders.
Posted Image
#29 oddcomp
oddcomp
    Subaru Master
  • 1,763 posts
  • longview ,wa
Posted 31 August 2005 - 10:12 AM
btw according to a fuel psi conversion utiliity for one of my megasquirt tuneing programs
240 cc/min at 43psi converts to
219 cc/min at 36 stock suby psi
now i assume the 36 psi we are supposed to get is only at idle ect
or is that the max full boost fuel psi the regulator provides? since that might be useful to know
#30 calebz
calebz
    Andys Coupe killed my cat
  • Administrator
  • 7,547 posts
  • Tacoma
Posted 31 August 2005 - 11:22 AM
Clayton, the Fuel Pressure regulator doesn't regulate at a straight 36 psi.
The regulator is setup to deliver a steady 36(point something) PSI above manifold pressure.
ergo, at 10 psi of boost, you should be seeing 46psi at the injectors
#31 Guest_shadow_*
Guest_shadow_*
  • Guests
Posted 31 August 2005 - 11:26 AM
The Subaru regulators should be 36psi at atmospheric. Under vacuum the pressure should drop, and conversely rise under boost. I still have my megasquirt set to 185, although 219 would be the proper number given the test results as Clayton said. A regulator from a 42psi car would be an upgrade in addition to fuel management, giving you the maximum from the stock injectors.
#32 oddcomp
oddcomp
    Subaru Master
  • 1,763 posts
  • longview ,wa
Posted 31 August 2005 - 01:43 PM
wel if i tell ms my injectors are much bigger than 200 cc then it starts to bog down even at idle
and this is with stock xt spider non turbo injectors on a turbo rx.. so go figure
#33 oddcomp
oddcomp
    Subaru Master
  • 1,763 posts
  • longview ,wa
Posted 31 August 2005 - 01:46 PM
thats kinda what i wanted to know is the when and where the max psi occured at
#34 oddcomp
oddcomp
    Subaru Master
  • 1,763 posts
  • longview ,wa
Posted 31 August 2005 - 01:54 PM
wow double post.. disregard one of these posts.. you choose wich one
#35 electryc_monk
electryc_monk
    Air-ride Airehead
  • 1,581 posts
  • Denton, Tx
Posted 07 September 2005 - 09:19 PM
free bump/subscribes...
#36 Myxalplyx
Myxalplyx
    Old Wise and Dumb
  • 1,838 posts
  • New Castle
Posted 08 September 2005 - 05:43 PM
Posted Image
Off of what car, year, model are these injector flow rates in reference too?
#37 Subarutex
Subarutex
    Oldschool Show Queen
  • Moderator
  • 2,551 posts
  • Mountlake Terrace
Posted 08 September 2005 - 06:40 PM
I'm just guessing... but I bet it was a 1988 RX.
#38 soobscript
soobscript
    needs more time
  • 705 posts
  • Columbus, OH
Posted 09 September 2005 - 03:25 PM
Correct!
#39 tizzle
tizzle
    Subaru Nut
  • 624 posts
  • Bellingham
Posted 19 October 2005 - 08:35 PM
So I got my RX injectors back from RC engineering. The results were good. Interesting to look at the before and after picture
Posted Image
you can see the cleaned on the right. The gap is wider, and they all came back a different color? wierd
off my donor engine never actually ran in my rx:
before/ after
221--Dripping/ 238 exc
230--good /240-exc
235--good /242-exc
1 with electrical damage
replaced with injector from car
220--good /240-exc
Interesting how the one that was actually on my car, had a good spray pattern but, the worst cc/min
